12 Pounds extra Tire weight?
Old Aug 10, 2013 | 11:06 AM
bobby777's Avatar
bobby777
Default 12 Pounds extra Tire weight?
With 12 lbs. extra tire weight from original weight of tires on the car--how does that affect performance?
Old Aug 10, 2013 | 11:53 AM
onlyavette's Avatar
onlyavette
Is that 12 per tire and wheel?
Old Aug 10, 2013 | 12:57 PM
lionelhutz's Avatar
lionelhutz
It's not the weight itself, it's the inertia of the tires that affects performance. More inertia hurts both acceleration and braking.
Old Aug 10, 2013 | 01:31 PM
bobby777's Avatar
bobby777
Its a total of 10-12 lbs.-all 4 tires-
Old Aug 10, 2013 | 03:25 PM
racebum's Avatar
racebum
this
it's inertia that's the problem
BUT
moving to a better tire that's unavailable in the smaller sizes often will give you a better overall car
for example. in z06 world guys often move to the PSS on the heavier tsw wheels. performance is better even though you're adding about 4lbs a corner
Old Aug 10, 2013 | 04:18 PM
bobby777's Avatar
bobby777
2001 Z06---Took my hard rock goodyear tires off--replaced with OEM size Firestone Firehawk tires--from what I have gathered about tires weights--the firestones are about 2.5 to 3 lbs a tire more weight--I really cant feel a performance lost but I can feel traction gain for sure-So I added about 10-12 total pounds of unsprung weight-
Old Aug 10, 2013 | 04:31 PM
racebum's Avatar
racebum
basically the same idea, heavier tire but more traction = better. did you check the date code on the firestones? they haven't been produced in awhile either
Old Aug 10, 2013 | 04:46 PM
bobby777's Avatar
bobby777
Yes my GY were hard as rocks--I bought the stones new in 2008/ date code confirms 0708-i was surprised that the GY were that much lighter--still had 7/32 tread-
Old Aug 10, 2013 | 04:49 PM
ZeeOSix's Avatar
ZeeOSix
Pretty insignificant amount ... highly doubt you'll notice any difference in acceleration or braking performance.
Old Aug 10, 2013 | 06:59 PM
racebum's Avatar
racebum
stones should be hard too. kind of curious why you didn't mount them in 08
if traction is a concern most people never run a tire over 3-4 years old
i do realize a lot of cruiser types go up to 10 years but the performance is REALLY down
Old Aug 10, 2013 | 07:20 PM
bobby777's Avatar
bobby777
I bought the tires in 08 to mount on chromies--never did--wraped the tires and awhile back had them mounted--very soft rubber especially compared to my old hard GY tires--not as wide as the GY--surprised they weigh a couple more pounds per tire==
Old Aug 10, 2013 | 09:02 PM
onlyavette's Avatar
onlyavette
A heavier tire does not equal better traction.
Old Aug 10, 2013 | 09:34 PM
bobby777's Avatar
bobby777
NO one said that--if a lighter tire like my old original goodyear is hard as rock--NO traction--a tire weighs afew extra pounds will kick the S--T out of my GY because its good soft rubber and hooks-
Old Aug 11, 2013 | 07:54 AM
PhysicsDude55's Avatar
PhysicsDude55
I would estimate that every pound of extra tire weight will AT MOST cost about 1 horsepower, and probably more like 1/2 of a horsepower.
So, 12lbs of tire weight, you're looking at a ballpark of 5-10 horsepower lost.
Old Aug 11, 2013 | 08:42 AM
Rob Petyo's Avatar
Rob Petyo
would this be close to a constant and still hold true as HP rises up the scale?
thanks ...
Old Aug 11, 2013 | 11:08 AM
onlyavette's Avatar
onlyavette
Ain't it funny how one little three letter word can change everything.
You do have to be careful about how much weight you add with your tire and wheel combination. Shock absorber dynamics are cause for concern too.
Old Aug 11, 2013 | 03:38 PM
ZeeOSix's Avatar
ZeeOSix
thanks ...
It would be a constant value for a constant wheel/tire mass amount and spin-up rate.
Not sure if I buy 1 HP per pound lost due to wheel/tire inertial spin up power loss. If that was the case, then if four wheels+tires (40 lbs ea) = 160 lbs, you'd be losing 160 HP? So if the engine was rated at 400 HP at the crankshaft, you'd only be getting 240 HP to the ground to accelerate the car? Even if it was 1/2 HP per pound that would be 80 HP due to 160 lbs of wheels/tires mass ... still seems too high.
To 12 Pounds extra Tire weight?
Old Aug 11, 2013 | 03:55 PM
racebum's Avatar
racebum
weight would have the biggest effect on transitions. braking distance. that first 200ft of launch etc.
once an object is in motion it has much less of an impact.
Old Aug 11, 2013 | 04:38 PM
bobby777's Avatar
bobby777
Lets say im drag racing--traction with the firestones is ok--go to all 4 tires that are 10 lbs lighter--again traction is ok-I really don't think my timeslip would vary much at all--with everything else being equal-
Old Aug 11, 2013 | 08:13 PM
spdislife's Avatar
spdislife
I've heard that 1 lb on the tires and wheels is equal to around 4 -6 lbs of sprung weight based on how far from the center of rotation the extra weight lies. That equates to roughly 50 to 60 more lbs..... or around 10 gallons of gas. I personally can't feel the performance difference between a full tank or quarter tabk of gas.
