98 c5 roaring in rear
Old Aug 11, 2013 | 07:52 PM
dj corvette's Avatar
dj corvette
Cruising
Default 98 c5 roaring in rear
between 35-70 mph makes humming kinda roaring sound in rear of car doesn't change much while turning dosent change while letting off of gas I jacked it up no 12-6 oclock movement but does have 3-9 oclock movement due to loose tie rod ends on both sides started it while in air quiet as a mouse from 0-70 mph it has 2010 grand sport wheels and nitto invo tires 19" im a newbie on vettes any help greatly appreciated
Old Aug 11, 2013 | 07:53 PM
dj corvette
Cruising
its a4 3.15 gears
Old Aug 11, 2013 | 11:01 PM
olbear1962's Avatar
olbear1962
Is it one sid or both? I had similar noise, and ended up changing my rear wheel hub bearings, noise went away.
Old Aug 12, 2013 | 04:15 PM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
The rear hub bearings would be my guess too.
Old Aug 12, 2013 | 05:30 PM
dj corvette
Cruising
cant pin point which side kinda sounds like both I know front tires has minor cupping on inside . and if I go over a dip it stops for a second
I guess it unloads for a second prob is bearings the rear tires look good they are nitto 19" 305/35/19 I think
Old Aug 12, 2013 | 07:04 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
How many miles on the car?
My '01 coupe started making a "roaring" sound a while back. The experts here immediately said, "wheel bearings", but I find it hard to believe that hub bearings would get loud (in my case) after only 20,000 miles. I'm thinking more like tires....
Old Aug 12, 2013 | 07:42 PM
dj corvette
Cruising
car has 175000 lol bought it from an older guy that used it for daily driver and has been well taken care of
Old Aug 12, 2013 | 07:45 PM
dj corvette
Cruising
I think a lot of it is im used to my 08 Silverado its extremely quiet on inside this is my first vette if u roll windows down u dot hear anything
Old Aug 12, 2013 | 11:43 PM
77BlueL82's Avatar
77BlueL82
Default Hubs
Had the same thing in my SRX.....rear wheel hub. Car was under warranty. I's expensive. Get a manual and do them yourself.
Old Aug 13, 2013 | 11:21 AM
olbear1962's Avatar
olbear1962
The replacement procedure is not difficult, I did mine myself. If you have a reputable shop, would be the way to go if you don't have the tools or a place to pull the rear hubs off?
If it is the bearings, I would suggest a non eBay cheapie set.
Old Aug 13, 2013 | 06:41 PM
leadfoot4's Avatar
leadfoot4
If I read this correctly, you're suggesting the CHEAP parts????
Old Aug 13, 2013 | 08:42 PM
dj corvette
Cruising
im a mechanic by trade just haven't worked on any later model vettes most bearings ive dealt with changes while turning unless its both bearings lol and make some noise on the stands and these don't . I was thinkin bearings or possibly these 14" wide tires but they look good. soon as I get this fixed its time to get it a little quicker I love this vette but kinda miss my 65 elcamino 11 sec street car that I trader for it but vette 26 mpg elcamino 11 mpg with no air lol thnx guys for the input
Old Aug 13, 2013 | 08:51 PM
Moto One's Avatar
Moto One
I just replaced my tires that were worn thinking that was the noise you have described. The noise is still there, and now seems louder (because of less noise with the new tires). I'll be changing the rear bearings hoping that its not a CV. 93k on my car by the way.
Mark
Old Aug 13, 2013 | 09:10 PM
BigGun's Avatar
BigGun
It's easy to check the lube in the diff. I would at least take a look.
To 98 c5 roaring in rear
