A/C compressor replacement
Old Aug 12, 2013 | 08:43 PM
ls6vettenc's Avatar
ls6vettenc
Default A/C compressor replacement
So today, the A/C compressor in my 03 z06 went out. It was blowing refrigerant all over the engine bay, I thought I had blown a head gasket. Anyway, the local dealership quoted me $1800 dollars for a new compressor and associated parts, they even want to replace the belt and tensioner. Should I let them do it? or find another shop.
Old Aug 13, 2013 | 08:47 AM
ls6vettenc's Avatar
ls6vettenc
bump......
Old Aug 13, 2013 | 09:56 AM
waddisme's Avatar
waddisme
New compressor: $300
Accum/orifice/etc: $100
Recharge: $75
$1300 for labor seems like a lot for me. I changed mine out myself. There are a couple of good vette shops around that would probably be cheaper and better. I use the ones in Mooresville, but if you ask in the Southeast Region section, there will be someone who might know of a reputable place closer to you.
Good luck with it.
Old Aug 13, 2013 | 10:07 AM
Chicago1's Avatar
Chicago1
DIY it's not that hard and saves you about 1k. Unless you have money to burn...
here is the write up on the how to
http://forums.corvetteforum.com/c5-t...-write-up.html
Old Aug 13, 2013 | 01:27 PM
ls6vettenc's Avatar
ls6vettenc
I ended up dropping it off at a local shop today. Quoted 800, or possibly less. All NAPA parts. Seems like a much better deal than the stealership.
Old Aug 13, 2013 | 01:28 PM
ls6vettenc's Avatar
ls6vettenc
I would, but I just don't have the free time at the moment.
Old Aug 13, 2013 | 01:58 PM
waddisme's Avatar
waddisme
If that includes recharging system, then that is a pretty good deal. For an experienced shop, I don't think there is anything special about doing a vette vs doing a Cobalt as long as they have the ac specialist.
Good luck with it.
Old Aug 13, 2013 | 06:42 PM
ls6vettenc's Avatar
ls6vettenc
Good luck with it.
I think this guy will do okay, he has worked on my truck a/c before, and its ice cold. He owns the shop, actually used to be a GM tech. He seems to think the compressor got too hot. When he put the car in the air, he said the condenser/radiator area was packed full of grass. I live in the country and people throw their grass in the roadway.
To A/C compressor replacement
