Possible coolant hose problem....
Old Jun 30, 2002 | 01:59 AM
steve badalamenti's Avatar
steve badalamenti
Default Possible coolant hose problem....
For the benefit of those who have not seen this tip previously:
Have a look at the small diameter coolant hose between the radiator and the surge tank atop the right
fenderwell. It is probably being cut through by the plastic radiator shroud just a couple of inches
from the radiator........... at least it was on my '99 H/T and a few other folks.
I slit an old spark plug wire boot and siliconed it around the area where it was chafing.
Old Jun 30, 2002 | 01:52 PM
carpe dm's Avatar
carpe dm
Default Re: Possible coolant hose problem.... (steve badalamenti)
Good hint Steve; I found this about a year ago and did the same thing. :yesnod:
Old Jun 30, 2002 | 04:35 PM
RedC5's Avatar
RedC5
Default Re: Possible coolant hose problem.... (carpe dm)
Ya....I put a small black zip tie over the hose to protect it.
Old Jul 1, 2002 | 08:17 AM
Smoke-N-Shot's Avatar
Smoke-N-Shot
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In VI Veteran
I found the same problem 2 years ago when I was swapping out some engine covers... It is good to protect the line of it will cause some coolant leakage down the road!
To Possible coolant hose problem....
