No Hazards or Brake Lights
Old Aug 14, 2013 | 06:03 PM
aobrien14's Avatar
aobrien14
Default No Hazards or Brake Lights
Need some help guys - 98 A4 Coupe - symptoms:
1. Hazards do not work (even when holding the hazard button depressed).
2. Brake lights DO NOT work under any circumstance (with headlights on or off).
3. All other lights are functioning when I turn the headlights on, including the tail lights.
4. With tail lights on, intensity does not change when I depress the brake pedal.
5. Cruise control will not engage (I assume because there's an issue in the brake circuit).
All fuses have been checked are in tact. I'm guessing that the hazard switch has failed, but need some guidance on solving this one. Thanks.
Old Aug 15, 2013 | 01:04 AM
Mr. Big's Avatar
Mr. Big
St. Jude Donor '07-'08
It is either the hazzard switch or blinker assembly. I would put my money on the blinker assembly. I had the same problem and replaced both, first the hazzard...no help, then the blinker..all fixed
Old Aug 15, 2013 | 12:57 PM
tacman's Avatar
tacman
St. Jude Donor '13
Do you have any LED's installed? Sequential turn signals? Seems these add-ons muck up the lights. You may need a JWM Hyperflash Harness. This item solved a similar problem with my '01.
Old Aug 15, 2013 | 01:40 PM
lionelhutz's Avatar
lionelhutz
Does the 3rd brake light work? If yes, then it can't be the hazard switch because the 3rd brake light power is tapped off between the brake switch and the hazard switch.
Do the signals work?
Old Aug 18, 2013 | 09:29 AM
dadaroo's Avatar
dadaroo
We need this input to determine the problem. Knowing if the 3rd brake light works is critical at this time.
Old Aug 18, 2013 | 11:12 AM
aobrien14's Avatar
aobrien14
Thanks for all the input guys. Was neither the hazard switch, blinker switch nor multi-function switch. Mechanic that did a tranny R&R for me must have pinched a conductor during the reinstall. Upon moving some cables around and applying the brake pedal we discovered the hazard switch fuse was blowing. At that point we knew it wasn't the hazard switch (because we had already replaced it). Played around with the pigtail at the back end and made sure all the cables running to the lights in back were loose and not pinched and problem solved.
To No Hazards or Brake Lights
