Valve Cover Spacer Clearance?
I am considering a coil relocate kit.
FYI 1/2" spacer from Jegs.
I do run this system in my CTS-V with an LS6 which has even less room, but it all fit.
Very tight.
Someone told me an alternator and bracket from an earlier year (01) has more clearance.
I measured it and I think if I replace the coil mounting bolt I might get the 1/2" clearance for the Jegs spacer.
Very tight.
-C- _C_C_C_ If you get my drift. You will need a longer wire if you do it that way though.
To much headache for me, especially when you consider all the aftermarket rocker failures (ether from manufacture error or operator/ install error).
If you get quality stuff, you usually won't have problems.
I haven't seen any failures on the 1500 system.
I got away with a 1/2" spacer, but I had to Dremel out every boss in the stock valve cover.
I Dremeled out every boss and baffle in the valve cover, then had to install a "catch can" as the oil was being sucked out of the vent hole.
You might want to check that coil relocation as it does what you want without the fuss, but with a 1" spacer I don't think you have a choice.
I measured the clearance in the pic I posted and I have just about 1/2" which will clear if I remove the mounting bolt from the coil.
I use a 1/2" spacer.
What I am considering is removing the coil mount bolt and replacing it with a "T" nut (in the coil hole) and installing a bolt the other direction.
That will still "hold" the coil and give me clearance.
What is a hoot is that my CTS-V had more room(!)
What I didn't tell you is that with the 1500 system (shown) I had to also increase the pushrod holes in the heads or they would rub on the sides.
The geometry puts the pushrod nearer the fulcrum point.
Where there is a will................
The picture below is the 1500 in my V.
