Help with trouble code
Old Aug 16, 2013 | 09:16 AM
Dmiles2004's Avatar
Dmiles2004
Default Help with trouble code
I just arrived at work after a 25 minute trip and all was fine . As I was parking the car started to idle rough and the check engine light came on. I pulled codes and the only current code was PCM P0300. Detected engine misfire. Any insight as to what I should start checking? I cleared the code and restarted and it seems fine now, but I don't want to get stuck on my way home.
Thanks guys & gals
Old Aug 16, 2013 | 09:38 AM
runner140*'s Avatar
runner140*
A place to start.....pull into a dark garage (night) lift hood and start engine. Look for a light show (spark gap from plugs or plug wires and anywhere else). Start with the easy things first. Get back to us.
Old Aug 16, 2013 | 09:41 AM
3boystoys's Avatar
3boystoys
Get a cheap Actron and keep it with you, if it pops up again, plug it in BEFORE you shut the engine off and see which cylinder is misfiring, most likely a loose wire.
Old Aug 16, 2013 | 09:49 AM
Dmiles2004's Avatar
Dmiles2004
Thanks guys. I was just coming in to update. It was in deed a loose plug wire. Kinda corroded as well. I'm going to replace all of the wired when I get home. Any suggestions on where to buy or brand to buy? Also should I go ahead and replace the plugs as well? The car has about 79,000 miles and I'm not the original owner.
Old Aug 16, 2013 | 10:20 AM
3boystoys's Avatar
3boystoys
Got my last set at Napa. Works fine.
Old Aug 16, 2013 | 12:00 PM
Dmiles2004's Avatar
Dmiles2004
Thanks for the plug wire lead. Anyone with an opinion on replacing the plugs as well?
Old Aug 16, 2013 | 01:12 PM
tacman's Avatar
tacman
St. Jude Donor '13
Default Wires n' plugs
GM HP red wires are often recommended and plugs may depend on engine mods. Readers can make suggestions if you post any mods.
Old Aug 16, 2013 | 01:21 PM
3boystoys's Avatar
3boystoys
Got the stock iridiums at Napa too, only #7 is really hard to do. Go with the .040 gap not .060.
To Help with trouble code
