Help!! Install Borla Stringer and now engine won't start.
Old Jun 30, 2002 | 12:16 PM
KENC5T's Avatar
KENC5T
Cruising
Default Paging C5 Tech, Help!! Install Borla Stringer and now engine won't start.
Just install the Stringer yesterday and now the engine won't start at all. The battery is fine and so is everything else. Now sure if it is the back pressure. Any help would be great!
[Modified by KENC5T, 10:02 PM 6/30/2002]
Old Jun 30, 2002 | 12:21 PM
JerryL's Avatar
JerryL
Cruise-In II Veteran
Cruise-In III Veteran
Default Re: Help!! Install Borla Stringer and now engine won't start. (KENC5T)
Reduced back pressure is not the problem.
Old Jun 30, 2002 | 12:24 PM
KENC5T's Avatar
KENC5T
Cruising
Default Re: Help!! Install Borla Stringer and now engine won't start. (JerryL)
Jerryl,
What do you think the problem might be? My car was running 100% before today.
[Modified by KENC5T, 4:25 PM 6/30/2002]
Old Jun 30, 2002 | 12:29 PM
MilYellow02's Avatar
MilYellow02
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11
wth :smash: :crazy: Someone will chime in here with some sense. Good luck :yesnod:
Old Jun 30, 2002 | 12:32 PM
PeterK's Avatar
PeterK
St. Jude Donor '12
2012 Election Contest Winner
Have you checked the codes? I assume you have power in the car?
Old Jun 30, 2002 | 12:42 PM
KENC5T's Avatar
KENC5T
Cruising
Default Re: Help!! Install Borla Stringer and now engine won't start. (PeterK)
Yes I have power in the car and have check the codes. No codes. I am wondering why the exhaust would prevent my engine from starting?
[Modified by KENC5T, 4:42 PM 6/30/2002]
Old Jun 30, 2002 | 01:11 PM
JerryL's Avatar
JerryL
KENC5T,
I'm far from an expert trouble-shooter; I'm just sure your problem is not due to reduced back-pressure. It sounds like some wiring under the car was disconnected or broken during the Stinger installation.
Old Jun 30, 2002 | 01:17 PM
jschindler's Avatar
jschindler
Does the car turn over with the starter? Did you do anything else - like under the hood? I can't imagine what a exhaust install would effect, except as noted above if you caught a wire while working on it. I'd crawl under the car and just look over everything. Let us know what you find so we can all learn.
Old Jun 30, 2002 | 01:18 PM
KENC5T's Avatar
KENC5T
Cruising
Jerryl,
Thanks for your suggestion! Anyone else have any ideas?
Old Jun 30, 2002 | 01:28 PM
KENC5T's Avatar
KENC5T
Cruising
Default Re: Help!! Install Borla Stringer and now engine won't start. (jschindler)
Just crawled underneath the car. Didn't see any wires damage. I would hate to have to toll the car. :cry
Old Jun 30, 2002 | 01:39 PM
Sam Lin's Avatar
Sam Lin
We need more details on the symptoms - what exactly happens, when?
I'd take some alcohol and clean off the contacts on your key's resistor, and spray a light blast of electrical cleaner in the ignition key slot, then wait 5 minutes, and I think that'll do it.
Sam
Old Jun 30, 2002 | 01:42 PM
KENC5T's Avatar
KENC5T
Cruising
Default Re: Help!! Install Borla Stringer and now engine won't start. (Sam Lin)
The engine doesn't kick over at all. I have an A4, and the car acts like it is in the wrong gear or something. When I turn the key, all I hear is the a click, but nothing happens. I will try a different key. Thanks for the suggestion.
[Modified by KENC5T, 6:28 PM 6/30/2002]
Old Jun 30, 2002 | 01:54 PM
hrdtopv8's Avatar
hrdtopv8
My buddy's '97 Camaro did the same thing. We figured out that although the shifter looked like it was in Park it was actually in Reverse(it was half way between)... This prevented the car from starting. I don't know what the underside of an A4 looks like but you might have pulled the tranny cable by accident. Try moving from Park to Drive and back into park again and see what happens. :chevy :seeya
Old Jun 30, 2002 | 02:07 PM
PeterK's Avatar
PeterK
St. Jude Donor '12
Check the gear selection. Seems like your car thinks that it is in gear instead of "park" and that prevents it from starting. Happens all the time on my mazDa. Just shift it from part to reverse and back.
Old Jun 30, 2002 | 02:12 PM
KENC5T's Avatar
KENC5T
Cruising
Thanks guys for the idea, tried that solution with no results. Keep any ideas coming guys. They are much appreciated.
Old Jun 30, 2002 | 02:18 PM
PeterK's Avatar
PeterK
St. Jude Donor '12
So you do hear the clicks under the hood or not?
Old Jun 30, 2002 | 02:24 PM
KENC5T's Avatar
KENC5T
Cruising
Yes I can hear the click under the hood. The weird thing is, after I install the exhaust yesterday. I was able to drive around all day without any problem. I do love the roar of the Borla Stringer though.
To Help!! Install Borla Stringer and now engine won't start.
Old Jun 30, 2002 | 02:37 PM
chocoholic's Avatar
chocoholic
Could you have a flat battery, perhaps?
Old Jun 30, 2002 | 02:39 PM
Patman36's Avatar
Patman36
Hey Ken. Hope you like the Stingers :D Anyways, I doubt the exhaust had anything to do with your car not starting (especially hearing that you were able to drive right afterwards).
Did you fill up with gas yesterday by any chance? Some have reported car troubles from the gas cap not being secured in place (three clicks to be safe). Maybe try that.
What kind of wires is the exhaust near guys? Anything major he may have accidently cut?
Patrick :cheers:
Old Jun 30, 2002 | 02:49 PM
jschindler's Avatar
jschindler
Default Re: Help!! Install Borla Stringer and now engine won't start. (Patman36)
The click is a classic sign of a low battery or loose conncection. It has enough juice to kick in the starter solenoid, but not enough to turn it over. Perhaps you left something on overnight that drained the battery.
