4L60E/65E transaxle dimensions?
Old Aug 20, 2013 | 07:34 PM
LiveandLetDrive's Avatar
LiveandLetDrive
Default 4L60E/65E transaxle dimensions?
Hi all,
I am planning to use a 4L65E in a custom car build, specifically one pulled from a 2005-2007(?) C6 Corvette with the A4 transaxle setup. This will be a scratch-built vehicle (Google "Lazareth Wazuma" if you'd like to see the approximate form) and I'm trying to determine some of the basic dimensions. Does anyone know of a source somewhere online with detailed dimensions of the 4L65E that is specific to the Corvette? Specifically I'm looking for:
  • What is the length of the main case alone? (Is this identical across cars and years after the 4L60E went to a separate bellhousing?)
  • What is the distance from the surface where the differential mates to the driveshaft centerline? (Or what is the overall length from torque tube to driveshaft centerline of the transaxle, and overall length to the rear of the diff?)
If someone would be willing to do some quick tape-measure work for me under their car that'd be awesome. I've done lots of searching here and on Google but the only measurements I could find were for other applications and differences between years, and nobody is swapping a Corvette-sourced 4L65E into their mid-trans, RWD car for obvious reasons.
I'm asking here as well as the C6 section as the 4L60E should be nearly identical in most respects.
Thanks in advance for any help!
