LS1 edit questions?
Old Jul 1, 2002 | 12:40 AM
Phil97SVT's Avatar
Phil97SVT
Default LS1 edit questions?
I am about ready to order LS1 edit so I can tune this car the way it should be. How are the fuel and timing table set up and how easy are they to interpert and modify? Who has the best price on LS1 edit?
Phillip :cool:
Old Jul 1, 2002 | 12:57 AM
cliffkh's Avatar
cliffkh
Default Re: LS1 edit questions? (Phil97SVT)
As far as I know, http://www.Carputing.com is the only place you can buy LS1 Edit. The tables are easy to modify through the Edit user interface. Check out LS1Tech.com forum on computer tuning - there are a lot of knowledgeable people over there working with LS1 Edit. Good luck.
Old Jul 1, 2002 | 01:17 AM
intel55's Avatar
intel55
Hmmmmm There are seperate "fuel" and "ignition" tab, which then breakdown into various other parameters. Fairly straightforward, but you will need the services of a dyno and wideband to get it all tuned corectly. Graphs really help interpret the data.
There is only ONE place to get Ls1edit, so no cuts on price unless you go in with someone else.
Go slllllllloooooooowwwwwwww :cheers:
To LS1 edit questions?
