Anyone using the ELM327 v1.5 bluetooth scanner?
Old Aug 27, 2013 | 09:17 PM
T_Vert's Avatar
T_Vert
Default Anyone using the ELM327 v1.5 bluetooth scanner?
It's the model Elm327 v1.5 and 2000 corvette. I've connected to my 2013 kia optima and 05 lexus rx330 w/o a problem. I also checked the disable ELM327 auto timing which it says to try if it has a problem talking to the car. It just goes through checking protocols until it asks if my ignition is on. I use it for my top down technologies and on occasion my hp tuners so I know the obd II port is ok.
This is what it is:
Amazon.com: V1.5 Super Mini ELM327 Bluetooth OBD2 OBD-II CAN-BUS Diagnostic Scanner Tool: Everything Else Amazon.com: V1.5 Super Mini ELM327 Bluetooth OBD2 OBD-II CAN-BUS Diagnostic Scanner Tool: Everything Else
Dave
Old Aug 28, 2013 | 05:22 AM
eldudereno's Avatar
eldudereno
I've got one and tried using 3 different Apps to hook it up with the Vette, failing each time when searching for the correct protocol. Works fine with my Jag and Ford. Didn't bother looking into it any further as I didn't buy it to use on my C5.
Old Aug 28, 2013 | 11:33 AM
StrangelovesM6Vert's Avatar
StrangelovesM6Vert
Mine worked with the TorqueMaster app for the Galaxy Note
Old Aug 28, 2013 | 11:52 AM
T_Vert's Avatar
T_Vert
Where did you find the torquemaster app? I looked around the app store and did not see it.
Old Aug 28, 2013 | 12:08 PM
StrangelovesM6Vert
Sorry
Search for torque apps
It's called Torque Pro which is 5.00
there's Torque Light which is free.
Try that first to see if it will sync with the module.
I'm not 100% sure it's the same module but mine is
Amazon.com: Super Mini ELM327 V1.5 Bluetooth OBD2 OBD-II CAN-BUS Auto Diagnostic Scanner Tool: Automotive Amazon.com: Super Mini ELM327 V1.5 Bluetooth OBD2 OBD-II CAN-BUS Auto Diagnostic Scanner Tool: Automotive
Old Aug 28, 2013 | 12:35 PM
T_Vert's Avatar
T_Vert
I have that same scanner and using torque it will not work on the vette. Worked on all my other cars though. Some are saying this one works:
Amazon.com: Soliport ELM 327 Bluetooth OBDII OBD2 Diagnostic Scanner: Automotive Amazon.com: Soliport ELM 327 Bluetooth OBDII OBD2 Diagnostic Scanner: Automotive
Dave
Old Aug 28, 2013 | 12:40 PM
StrangelovesM6Vert
Dave
That one will hang down from the port due to it's size.
The one I have is shallow and works with my 2002 vette
Old Aug 28, 2013 | 12:42 PM
T_Vert's Avatar
T_Vert
I'm aware. if you have a pic of the one you use I'd appreciate it. It seems nobody has been able to get the MINI elm327 to work on the c5.
Dave
Old Aug 28, 2013 | 01:07 PM
StrangelovesM6Vert
It's the same one that is shown in my link above.
Here's a picture to confirm it
Old Aug 28, 2013 | 01:14 PM
T_Vert's Avatar
T_Vert
Wow. Can you tell me what protocol you are using that worked? Mine works on every car but the vette and it will not find a protocol that will work on the vette.
Dave
Old Aug 28, 2013 | 01:53 PM
StrangelovesM6Vert
I just plugged it in and it worked I don't know what protocol is how would you find that
Old Aug 28, 2013 | 02:32 PM
StrangelovesM6Vert
The interfaces are not the same.
My interface is made by Generic according to Amazon while yours is a little bigger and made by OEM.
I can't guarantee that mine will work in your car but I don't see why not if it works in my car.
Old Aug 29, 2013 | 01:17 AM
T_Vert's Avatar
T_Vert
Mine looks identical to yours and won't work on the c5. Do you have a 2004 by chance? When torque connects does it show the protocol at the top?
Mine:
https://www.dropbox.com/s/tnjnhzrvxo...2000.14.25.jpg
Old Aug 29, 2013 | 02:06 AM
T_Vert's Avatar
T_Vert
So I just went and purchased torque pro and noticed it says this
Cheap clone versions of this adapter (mostly found on amazon/ebay) may not function with protocol J1850-PWM.
I got mine on amazon. Looks like I'll send it back. I got the "generic" one from amazon like you have. It looks like I've got the cheap knockoff. A whole $3 cheaper than that "Generic" one.
https://www.dropbox.com/s/z9ua92yl4o...2001.02.36.png
Old Aug 29, 2013 | 03:47 AM
StrangelovesM6Vert
My car is a 2002.
I'll check and see what it says when it hooks up.
Old Aug 29, 2013 | 09:06 AM
StrangelovesM6Vert
Ok
the OBDII Protocol is J1850VPW(10.4K)
Everything seems to be working fine.
I had to reboot my Note phone as it was showing that the Bluetooth was off and it was turning it on but was stuck.
Maybe check your settings and restart your phone.
These modules are like lunch money if you have to buy the one I have.
Old Sep 1, 2013 | 05:54 PM
T_Vert's Avatar
T_Vert
Well I went and got the "OEM" from amazon like you have and it does the same thing the "generic" one did. Works in all cars but the vette. Got the larger 327 (non mini) and it works in the vette like a champ. I'd really like to get a mini one working. I've restarted my phone a few times (have the Note II) and it's not worked yet unfortunately. tried to hard code the protocol and it still didn't work w/ the mini. I don't know where else I can buy this other than amazon or ebay. I can't find an authorized reseller for this ELM327 to make sure I don't have a cheap knockoff as torque states.
Ugh..
To Anyone using the ELM327 v1.5 bluetooth scanner?
Old Sep 1, 2013 | 07:31 PM
StrangelovesM6Vert
Well
I don't know what to tell you.
It works fine on mine and I'm also using a Note 2.
I also bought this one for the right angled cable I couldn't find by itself.
It fits real nice to a splitter so I can also run the window valet
and the ELM.
http://www.ebay.com/itm/350776610305...84.m1497.l2649
The modules are tucked under the dash up the pillar.
Somehow I misplaced the module that came with the cable and can't find it.
I was going to get another one for my Lincoln LS
like the one you just got so PM me if you want me to take it off your hands.
Old Sep 1, 2013 | 08:30 PM
T_Vert's Avatar
T_Vert
I'll return it to Amazon I . purchased 3 others to see if one works.
Old Sep 2, 2013 | 05:01 AM
StrangelovesM6Vert
I'll keep looking for my "lost" module.
Maybe the wife put it somewhere while "cleaning" LOL!
With the right angle cable it doesn't matter how long it is.
