Help! Corvette won't start 2002 Z06
Old Aug 31, 2013 | 10:08 PM
MITengineer's Avatar
MITengineer
8th Gear
Default Help! Corvette won't start 2002 Z06
So I've done some preliminary research. My car will intermittently not start (happened 1-3 times) and basically it does the following:
(1) Key will turn, but nothing happens at the starter
(2) All other electrical accessories are working
Then, although I have an LMC5 installed, the dreaded service column lock message came on today. Battery resting voltage is 12.0 Volts, which seems slightly low for a charged battery.
I know these cars have solenoid issues, but the low voltage is also a concern. is it possible that a new battery could be the source of both problems?
- Chris
Old Aug 31, 2013 | 10:23 PM
martysauto's Avatar
martysauto
St. Jude Donor '14
Did you check to see if you are getting battery voltage to the s terminal at the starter?
Old Aug 31, 2013 | 10:53 PM
MITengineer
8th Gear
Tested with a multi-meter across the terminals. The thing puzzling me is why would the steering column lock message come on?
- Chris
To Help! Corvette won't start 2002 Z06
