Just ordered Ls1 Edit...current user questions?
Old Jul 1, 2002 | 03:40 PM
Phil97SVT's Avatar
Phil97SVT
Default Just ordered Ls1 Edit...current user questions?
How easy are the tables to read and change? Are there any tips or hints to programming?
Phillip
Old Jul 1, 2002 | 03:44 PM
MattG's Avatar
MattG
Cruise-In I, II, III, IV & V Veteran
CI-I & II Auto-X Champ
Default Re: Just ordered Ls1 Edit...current user questions? (Phil97SVT)
Make sure to get on the LS1edit mailing list.. That is where you will learn tons!
Old Jul 1, 2002 | 03:46 PM
Phil97SVT's Avatar
Phil97SVT
Default Re: Just ordered Ls1 Edit...current user questions? (MattG)
Where is that located?
Phillip
Old Jul 1, 2002 | 04:30 PM
66ImpalaLT1's Avatar
66ImpalaLT1
http://www.ls1edit.com
Old Jul 1, 2002 | 06:02 PM
RWhite's Avatar
RWhite
Default Re: Just ordered Ls1 Edit...current user questions? (66ImpalaLT1)
I have used mine for resetting the shift characteristics on the auto tranny: easy to do. Also changed the idle across the range of engine temps. Easy stuff so far. Did some torque management changes also. Overall, the shifting now on the car from mild to aggressive is awesome!
Have not got into the engine yet. Waiting for my EASE to arrive. It may be at home today, as my wife said I got a package.
We did lower our 1/8 mile times to right at 8.0 secs Friday and had our first 1.79 60 ft. times (thanks to BFG DR’s). The heat is killing our overall times though, but I think I am going to get some weather monitors to help me at least feel better! We are running in 85F/85% weather. Boy that is rough when you try to compare you runs to the ones made in 55F/45% humidity earlier in the year!
Here in Texas, I will have to wait until October to get somewhat decent weather!
Old Jul 1, 2002 | 07:37 PM
Phil97SVT's Avatar
Phil97SVT
If you fuel curve is slightly rich over the entire curve from say 4500-6200 can you lean all of those values out equally and say richen it up equally from 6200-7000. I plan on revving it to 6600-7000. :crazy: How about the timing tables can you add say 1-2 degrees over an entire rpm band? Does torque management play a role with a 6 speed?
Phillip :boxing
Old Jul 1, 2002 | 07:47 PM
66ImpalaLT1
Torque management may play a role when TCS/AH or Competition mode is on. I am going to test out the theory next time I go to the track. Last time I was at the track I saw a 2 tenth difference between Competition mode and TCS/AH OFF.
Eric
Old Jul 1, 2002 | 08:10 PM
RWhite's Avatar
RWhite
We have notivced the same thing at the track, about 0.2 secs. We always run in the same mode you do.
Old Jul 1, 2002 | 08:19 PM
Phil97SVT's Avatar
Phil97SVT
Default Re: Just ordered Ls1 Edit...current user questions? (RWhite)
What about adjusting the tables?
Phillip
Old Jul 1, 2002 | 09:42 PM
ToplessTexan's Avatar
ToplessTexan
Cruise-In II Veteran
People are still arguing about how to deal w/ TM. Part of the problem is that it's difficult to sample a short duration event, e.g. a timing pull during a shift, in order to actually see what's going on. The other problem is that while requests for torque reduction from external modules like the EBTCM are relatively well understood, requests generated within the PCM algorithms are not.
Old Jul 1, 2002 | 09:44 PM
ToplessTexan
"Tons" is a charitable description, but there are some characters there that don't frequent other places.
Old Jul 1, 2002 | 10:11 PM
DUKE's Avatar
DUKE
Read en and change en part is simple. Knowing what to change is where you will be concerned....its a great program.
Old Jul 2, 2002 | 02:46 AM
enloe's Avatar
enloe
Which mode (TCS/AH or Competition) is faster?
Old Jul 2, 2002 | 09:47 AM
RWhite's Avatar
RWhite
Default Re: Just ordered Ls1 Edit...current user questions? (enloe)
We have found that the Competition Mode is defintiely quicker in the 1/8 and 1/4 mile.
Old Jul 2, 2002 | 09:52 AM
ToplessTexan
I think he meant between AHS/TCS in Competition Mode and AHS/TCS completely off.
To Just ordered Ls1 Edit...current user questions?
