Sway Bar Question ?
Old Jul 1, 2002 | 04:11 PM
clubber's Avatar
clubber
Cruising
Default Sway Bar Question ?
I have too much body roll. I wanted the Z51 package, but I ended up buying a car the dealership already had on order (w/o Z51) to get the low apr deal. Anyway, is it possible to just get the dealership to order the Z51 sway bars and springs, or should I just spring for the $500+ Hotchkis Kit ?? Also - what about lowering it ? Any suggestions would be helpful. :seeya
Old Jul 1, 2002 | 04:19 PM
mbtc5vette's Avatar
mbtc5vette
Default Re: Sway Bar Question ? (clubber)
Get the Z06 bar kit from Fichtner's. $231 - less than half the cost of Hotchkis.
:cheers:
Old Jul 1, 2002 | 04:24 PM
allanlaw's Avatar
allanlaw
Default Re: Sway Bar Question ? (mbtc5vette)
:cheers:
It will greatly reduce body roll and make your car track like a train.
Old Jul 1, 2002 | 09:36 PM
MySea6's Avatar
MySea6
:cheers:
Since you have an 02', all you need are bars and isolator bushings. (~$170 from Fichtner) Also, there is a huge difference in the std. and Z51 shocks. You might want to look in to a shock change also. Bilsteins were my preference. :cheers:
Old Jul 2, 2002 | 03:20 AM
clubber's Avatar
clubber
Cruising
Default Re: Sway Bar Question ? (MySea5)
Thanks for the reply ! Is Fichtners a dealership or what ? Can you give me the info. on them ? - Thanks again.
Old Jul 2, 2002 | 08:43 AM
Arnie's Avatar
Arnie
Cruise-In II Veteran
He is a supporting dealer and a great help to the forum, go to the Ken's Newsletter section of the forum for further info.
[Modified by Arnie's C5, 7:57 PM 7/2/2002]
Old Jul 2, 2002 | 08:51 AM
RyanC7's Avatar
RyanC7
:cheers:
What is the advantage of the 02 and the price break what does it have that the others don't?
:seeya
Old Jul 2, 2002 | 10:12 AM
mbtc5vette's Avatar
mbtc5vette
Default Re: Sway Bar Question ? (Ryan2002C5)
I think all 02's already come with the metal end links instead of the plastic ones that were on earlier models so you wouldn't have to buy them. (I think that's true for all '02s and not just the Z06's. Can someone confirm?) Good point and will save you even more $$$. As noted above, Fichtner's is a supporting dealer in Montana that sells GM parts a lot cheaper than most dealers and ships anywhere. Bob, the parts mgr., is a great guy and very helpful. Great service. Bob's # is (406) 628-4121.
:cheers:
Old Jul 2, 2002 | 11:29 AM
ersatz928's Avatar
ersatz928
For a complete Z06 suspension set-up, you need the front Z06 bar, 4 Z06 shocks, the stiffer rear spring, and a Z51 rear bar, and all 4 metal end-links.
Old Jul 2, 2002 | 12:28 PM
powderski13's Avatar
powderski13
Huge difference after I put the Z06 bars on my base suspension vert. I will add Z51 springs and Bilstein Sport shocks before I lower it.
:flag
Old Jul 2, 2002 | 01:24 PM
clubber's Avatar
clubber
Cruising
Thanks dude. I just ordered them from Bob. Should be here in a week. :flag
Old Jul 2, 2002 | 11:21 PM
Mark VerMurlen's Avatar
Mark VerMurlen
I have a 2002 Coupe with the F45 suspension and I can confirm that it came with stock metal end links. So I would guess that all coupes and verts, as well as Z06's, now come with metal end links. I put the Z06 sway bars on my car last weekend.
- Mark
Old Jul 2, 2002 | 11:33 PM
jeanlucpicard's Avatar
jeanlucpicard
I have a 2001 convertible and have been looking hard at the Hotchkis front and rear sway bars with metal adjustable end links. Cost is about $550. Are the Z06 sway bars the same diameter as the Hotchkis? I autocross and want to reduce body roll. I have F45 adjustable suspension so I am also interested in the more agressive monosprings to help body roll and response. Any suggestions on spring weight?
Appreciate any help.
Save The Wave :cool: ;)
Old Jul 3, 2002 | 10:04 AM
mbtc5vette's Avatar
mbtc5vette
Default Re: Sway Bar Question ? (jeanlucpicard)
The Hotchkis bars are reputed to be stiffer than the Z06 bars - good for autocross but some people have found them too punishing for everyday street use. Not sure of relative diameters - maybe Hotchkis or one of the Forum vendors that sells them can tell you. The Z06 front bar is hollowed out inside to reduce weight, also not sure about the Hotchkis.
:cheers:
Old Jul 3, 2002 | 04:06 PM
Jochen's Avatar
Jochen
Yes, the 02 comes all with metall end links. I saw a picture one by one. Will upgrade in the future to the new design.
Jochen
To Sway Bar Question ?
