Service active handeling warning and limp mode issue
-P0507 Idle Speed High
-P1516 Command vs Actual Throttle Position Performance (TAC Module)
-C1278 TCS Temporarily Inhibited By PCM
-C1293 DTC C1291/C1292 Set Curnt/Prev Ign Cylce
3 times in the last month of driving ~500 miles, the car will seemingly randomly go into limp mode with error messages on the dash reading: "reduce engine power, service active handeling/TCS system". Every time I've been able to restart the car after stopped and it runs OK. Twice this happened on the freeway and I was luckily able to pull off in a safe place to restart the car while stopped because restarting while it was still in motion would put it back to limp mode.
Not sure if this is related, but around the same time this started, my speedo started working intermittently and only accurately reads my speed going over 50mph, any less mph and it bounces around or reads 0mph.
Any help is truly appreciated!
I did just start getting the "service column lock" warning yesterday, not sure if it's related?
PCM P1515 - Control*Module*Throttle*Actuator*Positio n*Performance
TSC C1221 - LF*Wheel*Speed*Sensor*Input*Signal*is*0
TCS C1222 - RF*Wheel*Speed*Sensor*Input*Signal*is*0
TCS C1248 - DRP*Disabled*
TCS C1278 - TCS*Temporarily*Inhibited*By*PCM
LDCM B2282 - 12V*Power*Feed*#1*Fault
LDCM B2284 - 12V*Power*Feed*#2*Fault
RDCM B2283 - 12V*Power*Feed*#1*Fault
RDCM B2285 - 12V*Power*Feed*#2*Fault
RDCM B2265 - Mirror*Vertical*Position*Sensor*Fault
