Charging System Fault?
Old Jul 2, 2002 | 09:45 AM
HBJ's Avatar
HBJ
Default Charging System Fault?
I started up the coupe last night after a few days in the garage. The above message appeared on the DIC. The car started normally, the message disappeared immediately and did not reappear. Anyone know what it might mean?
Old Jul 2, 2002 | 10:42 AM
RDRH8R's Avatar
RDRH8R
Default Re: Charging System Fault? (HBJ)
Mine recently did the same thing. The owners manuel says if the problem persist then the message will appear every ten minutes. Mine never came back.
Old Jul 2, 2002 | 11:24 AM
ersatz928's Avatar
ersatz928
Default Re: Charging System Fault? (Readsvette)
Either the voltage was too high or too low, or there is a non-functional field coil in the alternator.
Old Jul 2, 2002 | 11:38 AM
Charley Hoyt's Avatar
Charley Hoyt
Default Re: Charging System Fault? (ersatz928)
I get that message at leaset once a week. I have had it to the dealer three times and they say everything is working fine???I did a search on the forum and found that several people have resolved this by fixing some grounding issues. I told the dealer this and they said that they checked and all is fine??? Time will tell.
Old Jul 2, 2002 | 06:08 PM
Z28Marcus's Avatar
Z28Marcus
Check your battery!!
I had this occur after pulling the vette outa winter strorage and finding batt was flat (dumb butt here forgot to disconnect batt.). I recharged it and it seemed fine. Then coupla days later the car wouldn't start. 1 jump-start from a collegue at work and then a recharge, it seemed ok again.
2 days later I got the charge system fault message. When I opened the hood I found one of the the vent caps (Optima red top) had blown off and sprayed a small amount of acid under hood :eek:. Damage was minimal (paint). Battery was totally shagged.
Just a heads up for ya.
Old Jul 2, 2002 | 06:12 PM
AMGPilot's Avatar
AMGPilot
Default Re: Charging System Fault? (Z28Marcus)
Wow that is strange, I came here today to look for this exact topic and it was right on top! I had the same thing happen to me two days ago but it has not ocurred again since. I guess it is okay then :)
Old Jul 2, 2002 | 10:28 PM
1999 White C5 Coupe's Avatar
1999 White C5 Coupe
HBJ,
I received the same message when starting my 1999 C5 coupe. The dealer was "stumped" despite several visits and called Chevrolet Technical Assistance.
The technician was instructed to check several ground locations on and near the starter (under the battery tray). He found several nuts that were loose on the studs, with corrosion present. He cleaned the locations and tightened the nuts. Since then, I have not received the DIC messages.
The technician stated that Chevrolet Technican Assistance immediately knew what the problem was and it must be fairly common (since they knew).
Good luck.
To Charging System Fault?
