Fan connector part # needed
Old Sep 14, 2013 | 03:14 PM
95wht6spd's Avatar
95wht6spd
Default Fan connector part # needed
Need to get the part # for the 2 wire male connector that plugs into fans.
Anyone know? Thanks
Old Sep 14, 2013 | 04:55 PM
LoneStarFRC's Avatar
LoneStarFRC
Anyone know? Thanks
GM 12101917
AC Delco PT189
Airtex/Wells 1P1028 (least expensive)
Old Sep 14, 2013 | 05:42 PM
95wht6spd's Avatar
95wht6spd
Thanks, I also found they are metri-pack 630 series.
Old Sep 14, 2013 | 06:17 PM
LoneStarFRC
If you know what terminal pins or connector body you have and want to make your own pigtails, etc, check Mouser.com. They carry the Delphi individual connector bodies and terminals and use the GM part numbers. They just add a three-digit number prefix (829) to the eight-digit GM part number to signify "Delphi". The terminal pins in that connector btw are considered females. There is no minimum purchase for in-stock items. Look for the "L" at the end of the terminal part numbers signifying "loose" if you just need a few.
HTH
Old Sep 14, 2013 | 06:29 PM
95wht6spd's Avatar
95wht6spd
Thanks, I found some pigtails local, under BWD pt299.
I would rather not use a competitor anyway, I work for Newark.
To Fan connector part # needed
