Service traction control
Old Sep 16, 2013 | 02:31 PM
AllanE's Avatar
AllanE
Navigator
Default Service traction control
Hey all,
For a while now, every so often when I turn my 01 corvette on I get a message saying service traction control/abs. Was wondering if anyone can help me with getting rid of it?
Old Sep 16, 2013 | 02:44 PM
wbrands's Avatar
wbrands
I'm having the same issue intermittently on my '01, getting code C1214 I think (you should pull yours and see what you're getting). I have decided I'm having the EBCM failure that appears to be fairly common in these cars. Can be very expensive (north of $1,000) at stealership to remove and replace to a couple hundred to send it to ABS Fixer for repair, to time and effort as noted in the link below. Check it out at:
http://forums.corvetteforum.com/c5-t...r-fleabay.html
Old Sep 16, 2013 | 03:17 PM
xzo124's Avatar
xzo124
Originally Posted by AllanE
Hey all,
Yep , check your codes .. Mine turned out to be Front wheel speed sensors. Did both of mine for $316.00 Autozone Lifetime parts....xzo
Old Sep 16, 2013 | 03:48 PM
AllanE's Avatar
AllanE
Navigator
Alright I cleared all my codes
on my TCS I have 1 code that I can't get rid of
C1214 H C
Where do I go from here?
Old Sep 16, 2013 | 04:36 PM
BigGun's Avatar
BigGun
C1214 H C
Check the link in post #2. Good information! Your ebcm needs to be replaced or fixed. Having it fixed is a much better option price wise. Pull the module or pay someone to remove it for you and send it to one of the many abs fixers listed on e-bay.
Old Sep 16, 2013 | 05:10 PM
guido7834's Avatar
guido7834
Check the sensors at the wheels. I had the same intermittent issue and cleaned the connectors and it hasn't happened since. Just an idea.
To Service traction control
