Problem with Dewitts 97-00 Auto Radiator
Old Sep 19, 2013 | 10:28 AM
jd_black_00's Avatar
jd_black_00
2016 C5 of the Year Finalist
St. Jude Donor '12, '14
Default Problem with Dewitts 97-00 Auto Radiator
Hi Guys,
I installed my Dewitts Radiator last night (1139097A) and everything connected up without issue. When I started adding coolant to the system the compression fitting at the lower transmission inlet was seeping coolant. I tried tightening up the fitting, but everything was tight already and it was still seeping coolant. When I tried to apply pressure something stripped. Has anyone had this issue? Dewitts is supposed to call me later today to try and help. Thanks in advance for any insight...
