Need help fuel issue!
If it's cranked up (or activated) all, or most of the time, your FP is getting hit with much higher than normal voltages, like 15-17 volts. The contacts in the FP relay are not particularly happy with all the extra current flow being demanded by the FP either, hence the hot relay. Not good.
If your going to run a BAP on a street driven car, I recommend using an rpm-activated switch, since it will only hit the pump with higher voltages when you go WOT (when you mainly need it in the first place). There are several on the market (Zex, Jegs, Intellitronix) and some can be adjusted to suit your "turn on" points.
Vacuum set-up hits the FP every time you start the car (or even just turn the key on) as there is no/low vacuum during that time plus, depending on where the vacuum switch is set, it may also activate at other times when you really don't need it, i.e. part throttle during regular driving if the vacuum drops below the threshold of the switch.
Bottom line is more wear and tear on the FP. The higher current draw being demanded by the FP that is going through the FP relay contacts, will prematurely shorten it's lifespan as well. The fact that it's getting hot is a warning sign, plus fitting loosely won't help matters either.
I agree with BigGun, a fuse won't open then close. That sounds more like a circuit breaker somewhere in the circuit (inside BAP maybe?) Jose also makes a good point about a possible loose wire/connection somewhere as well.
You may also have more than one problem and I wouldn't rule out the BAP it self as a potential trouble source either, since it has direct contact with the FP and it's functioning.
HTH
