Lowering car and alignment
Old Jul 2, 2002 | 09:41 PM
bigDvette's Avatar
bigDvette
Default Lowering car and alignment
I successfully lowered my car this weekend. Also, got some Bilstein Sports in at the same time. Getting the shocks out in the rear was painful. Really, I crunched my finger.
Anyway, it is down as far as the stock bolts will go and now I'm going to remove the front bolt and take a little bushing off so I can adjust it down more if I want.
I have one more question though. I've heard you should get a 4 wheel alignment after you do this. I know everyone does not agree. My question is 2 fold.
1) Where is a good place in the DFW area to have a 4 wheel alignment on a vette done?
2) If you want to get an alignment so the car is set up like the Z06 alignment (I autoX in this car primarily), how do you do that. Do you tell the shop and they look up the z06 specs, you tell them how you want it ???
Any help appreciated.
:flag
Old Jul 2, 2002 | 09:52 PM
Patches's Avatar
Patches
Default Re: Lowering car and alignment (bigDvette)
bigD, someone else recently asked this question. For myriad, no, a plethora of different opinions, suggestions and spec listings, do a search on alignment and settle down for the evening for some intense and,perhaps, informative reading. :yesnod: :crazy:
Old Jul 2, 2002 | 10:36 PM
Mark VerMurlen's Avatar
Mark VerMurlen
I lowered my car last weekend by about 3/4 inch and had it aligned today. It did need it. You tell the shop the car model you want to use numbers for and they'll look it up. However, I don't think you can use the Z06 alignment specs with the Goodyear runflats, if you still have them. I used the standard Corvette alignment specs since I still have the OEM runflats. My next mod is going to be replacement of the OEM tires with non-runflats. Then I'll change the alignment to Z06 specs.
- Mark
Old Jul 2, 2002 | 11:30 PM
zcobra1's Avatar
zcobra1
Default Re: Lowering car and alignment (Mark VerMurlen)
As Mark stated, no Z06 alignment w/ the runcraps. Shoulder of runcraps is way too squared off and stiff. You can go 1 degree neg. camber with non runcraps, really helps plant the car.
And yes, do get an alignment.
Old Jul 3, 2002 | 12:13 AM
bigDvette's Avatar
bigDvette
Default Re: Lowering car and alignment (zcobra1)
Thanks, I didn't realize the runcraps had issues.
I have gForce KD tires, but they are the SSS (BFGoodrich version of EMT), would those work?
Old Jul 3, 2002 | 05:33 PM
pburant's Avatar
pburant
It's the stiff sidewall of runflats that makes them work poorly with a Z06 alignment. I had my mechanic align my car halfway between regular C5 and Z06 spec, and between that and the 1/2" lowering (done at the same time), I have a measureable improvement in handling. I'm getting 2-4mph more out of some very familiar turns.....
Old Jul 3, 2002 | 06:07 PM
Mark VerMurlen
I think that the Goodyear tires have stiffer sidewalls than the other run flat tires. This is what gives then farther range and speed when flat than other tires. So the BFGoodrich tires may be able to handle more negative camber. You'll probably have to check with BFGoodrich to get an answer to this.
- Mark
Old Jul 3, 2002 | 06:57 PM
alanh's Avatar
alanh
You made the statement that you primarily auto-x the car. If that is true, then the majority of your tire wear is at the track, not the street and you would be able to run Z06 specs on the runflats just fine because most of your tire wear is going to be on the outside edges from cornering, not the inside edges from street driving. Just watch the tread wear closely and you'll know if you need to increase or decrease the camber from the Z06 spec of -.75 degree.
Old Jul 3, 2002 | 08:19 PM
jayleone's Avatar
jayleone
I just got mine aligned, but I also put much wider tires on at the same time. It drove perfectly fine before the alignment and I couldn't tell any difference in the ride afterwards (although I havn't pushed it very hard to test the handling yet.) The shop said it was way of from the Z06 specs I requested. So the moral of the story is, you should probably do to spare your tires.
To Lowering car and alignment
