I fixed up my 99 FRC (40 K mi.) from a wreck and everything turned out good except that it diesn't seem to want to go all the way into reverse (6 speed) and takes a couple of tries. I've had the shifter apart, inserted the nutral lock pin, loosened and tightened everything, and took the top off to check the plastic gizmo on the bottom - OK. No joy. Any ideas? Thanks, Bob
+1 check that out I shorted that out when I had my c6z and it wouldnt go into reverse... fixed the short and it worked perfect... also there should be a fuse for it so check that out as well
I don't know why more people aren't aware of the relatively common T56 reverse problem. I would first adjust the shifter to make sure that's not causing it to pop out, but if that doesn't immediate fix the problem, this is what you need to do:
