Driver's Lumbar Support
Old Jul 3, 2002 | 01:39 PM
Terry34's Avatar
Terry34
Default Driver's Lumbar Support
My lumbar support adjustment and side bolster adjustment on the sport seat on the driver's side only have stopped working. There is a soft whirring noise when I try one of the switches but no adjustment takes place. the passenger side works fine. Any ideas?
Old Jul 3, 2002 | 02:41 PM
SteveL2's Avatar
SteveL2
Default Re: Driver's Lumbar Support (Terry34)
The support is actually an inflatable bag inside the seat. My guess is if you are hearing a whir, then the motor that inflates the bag is still working, which is good news. :) But, it likely means that one of the plastic tubes that affixes to the bag has come off, so it is not getting inflated.
Getting inside the seat is not too hard, but it can be time consuming. Since it's both the lumbar and the bolster, the problem may be either behind the "insert" in the seat or underneath the seat bottom cushion, rather than inside the leather. To understand what I mean, here's a link: http://www.vetteessentials.com/instr...tructions.html
Go to the 4th set of instructions, entitled "C5 Custom Seat Cover Installation Procedure". Getting to just the bottom of the seat should take less than 30 minutes, which involves taking the seat out of the car. If you have to take leather off, that'll increase the time 2 or 3 fold.
Good luck. :seeya
[Modified by SteveL2, 12:43 PM 7/3/2002]
Old Jul 3, 2002 | 02:50 PM
THRAP 42's Avatar
THRAP 42
Presuming that the whirr you're hearing is the pump and it is working good. I would check the hoses that pass the air to the bladders. I would think you have a hose off on the pump.
later
To Driver's Lumbar Support
