Service Active Handling
Old Sep 30, 2013 | 07:51 PM
TEECEE's Avatar
TEECEE
Default Service Active Handling
I am getting this warning, only on occasion on my 2002 C5. SOmetimes upon starting car and also while driving. Any suggestions? Do I need to get this checked out or could it be an error? Maybe disconnect the battery???
Old Oct 23, 2013 | 08:46 PM
ace147's Avatar
ace147
Remove module and send to module masters for rebuild. Common problem with poor solder joints failing due to vibe.
Old Oct 23, 2013 | 10:21 PM
coia96vette's Avatar
coia96vette
With out the dic codes it is just a guess. Do as 8VETTE7 says and pull the codes and post. It could a number of different things.
Old Oct 24, 2013 | 12:59 AM
LoneStarZ06's Avatar
LoneStarZ06
I am having a similar problem...Mine came on about a week ago just on my way to work...when I got to work I checked the dic codes and none other then Historical codes. I reset codes but have not had it come on again. The check engine light has done the same thing twice since comes on for awhile then goes out. no codes checked oit belts etc nothing wrong.
Old Oct 25, 2013 | 11:00 PM
ace147's Avatar
ace147
Originally Posted by 8VETTE7
Don't discount H codes. They are an audit trail of things that have happened. Most codes will change from C to H once you turn off the ignition.
Next time the light(s) come on, pull your codes BEFORE you shut off the ignition.
CHECK Engine light can indicate that an emissions issue/event has occurred. Again pull the codes BEFORE you shut off the engine. If the light goes out on its own then the H codes can help you identify what occurred.
The failure is loose solder connections, so sometimes the code is active and sometimetimes inactive (H). Once you see the codes, just assume its bad and send to module masters. Hope is not a plan.
Old Oct 26, 2013 | 12:39 AM
LoneStarZ06
Thanks for the great info will do next time it happens
Old Oct 26, 2013 | 12:44 AM
LoneStarZ06
Which Module?
Old Oct 30, 2013 | 12:35 AM
ace147's Avatar
ace147
Originally Posted by LoneStarZ06
Which Module?
Ebcm. Found a really great pdf about it a year ago. Cannot find it easily now. Detailed all the areas with colder solder joints that failed in the modules as well as components prone to failure.
Old Nov 5, 2013 | 10:10 AM
Richard Thomas's Avatar
Richard Thomas
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
It's here. Post 65.
http://forums.corvetteforum.com/c5-t...in-here-4.html
I'm currently having the same issue. 2004 Z06 Will need to pull codes.
Richard
Old Nov 5, 2013 | 07:31 PM
xzo124's Avatar
xzo124
When it came on in my car , I pulled the codes per 8VETTE7 suggested and it was the speed sensor on Lf.on 1 list and Rf on another . Never theless I now have 2 new speed sensors on front ...FIXED...xzo to 8VETTE7
Old Nov 7, 2013 | 02:54 PM
lloydainey's Avatar
lloydainey
I am having the same problem
In addition, the car wants to reduce power. It actually shutsoff the radio
Old Nov 8, 2013 | 12:19 AM
BigGun's Avatar
BigGun
So why don't you pull the codes as suggested and start your own post. Reduced power mode is typically NOT a ebcm problem.
Old Nov 8, 2013 | 11:38 AM
lloydainey's Avatar
lloydainey
I had a similar problems
Check Gauges
Service active Handing
Tire pressure not reading
reducing engine power
but only when I turned on the Radio
turn it off, everything goes back to normal having reset each warning
turn the radio on, all the gauges go to zeor...fuel, temp, oil battery remains 13 volts
this all happened after I left the car for 10 days, and I had a usb plug in the cigaretter lighter outlet.
TODAY...EVEYTHING IS FINE.
Old Nov 9, 2013 | 02:43 PM
GeneT's Avatar
GeneT
Remove the ECBM and send it out to be re-soldered. You can have it done for as little as $50 incl return shipping. I 2-day shipped and had mine back and re-installed in 5 days. It's a very easy DIY fix. PM me if you want the info I have, i.e. repair address, removal instructions with pics, etc.
older CF thread
http://forums.corvetteforum.com/c5-t...r-fleabay.html
To Service Active Handling
