Help - DIC went nuts
Old Jul 3, 2002 | 04:52 PM
Hernan's Avatar
Hernan
Default Help - DIC went nuts
My car has been pretty reliable, but something wierd happened last night (when I was leaving the office at 2 AM after a 17 hour day). I turned the key and there was no reaction from the starter, but the DIC indicated every error message, one after the other.
Took all night to get a tow truck, the battery was fine. Got it to the dealer and now the dealer is saying they have never seen anything like it (and they specialize in Corvettes).
They confirmed that all the codes but the ABS were set off, and that the car does not send power to the starter.
Has anyone heard about this, or worse had it happen.
Please help. :sad:
Old Jul 7, 2002 | 04:43 AM
97c5er's Avatar
97c5er
Default Re: Help - DIC went nuts (Hernan)
check your passenger side floor see if its wet,a/c drain hose could be stopped up causing the the water to backup and drain onto your bcm that is under the kick panel.hope it didnt fry the bcm :eek:
Old Jul 7, 2002 | 04:59 AM
kewlbrz's Avatar
kewlbrz
Cruise-In II Veteran
Cruise-In III Veteran
Default Re: Help - DIC went nuts (97c5er)
I concur. I've seen your exact problems occur first hand to a friends at the drag strip. His finally dried out enough to work.
Old Jul 8, 2002 | 01:06 PM
Hernan's Avatar
Hernan
You guys amaze me:cheers: there was no water on the floor, but that is exactly what happened.
BTW the car is 100% again :D
Old Jul 8, 2002 | 02:07 PM
97c5er's Avatar
97c5er
Default hey hernan
just a little f.y.i.,get a large zip lock bag put your bcm inside zip it closed by the wires at least you wont have to worry about your bcm going up in smoke,you were lucky may not be so next time,mike :cheers:
Old Jul 9, 2002 | 02:44 PM
SpeedracerZ06's Avatar
SpeedracerZ06
Default Re: hey hernan (97c5er)
How does water get in there?
Old Jul 9, 2002 | 06:37 PM
97c5er's Avatar
97c5er
Default a/c drain hose stopped up
the a/c drain hose stops up and backs up
To Help - DIC went nuts
