GMPartsDirect brings up 18038570 for front pads and dealer is refering to 12530681. Whats the difference? Similarly for the rotors one source refers to 10445856 to 9 and the other 88925547 to 50.
:confused:
Thanks for the help.
:cheers:
The 12530681 is for the 01 Z06 front pads for sure.
The 18038570 might be for the C5 GM Durastop Brake Pads.
I have the info at home, I'll get it for you late tonite if noone replies by then.
:confused:
:cheers:
:confused:
:cheers:
Here are the part numbers for the stock rotors...
10445856 rotor front right
10445857 rotor front left
10445858 rotor rear right
10445859 rotor rear left
