Hissing sound in engine
Old Oct 4, 2013 | 02:06 PM
BOBS40th's Avatar
BOBS40th
Default Hissing sound in engine
I have a 2000 automatic convertible. I have deloped a hissing sound in the engine. I have plugged each vacuum line individually and this is not where the sound is coming from. I can't seem to find it anywhere. Has anyone had this problem, and if so, please let me know how you solved it. Thanks for any suggestions.
Old Oct 4, 2013 | 02:38 PM
runner140*'s Avatar
runner140*
Hate to say it but keep looking.....vacuum leak on the way to the power brakes? Is everything working okay...like your HVAC?
Many lines under the battery and behind the manifold.
Get back to us...
Old Oct 4, 2013 | 03:05 PM
Mattie Num Nums's Avatar
Mattie Num Nums
Mine hissed it was a plug way behind the intake manifold. Very small but loud!
Old Oct 4, 2013 | 03:46 PM
pit-man's Avatar
pit-man
Spray Carb Cleaner any where there could possibly be a leak. The rpm will pick up when you find it.
Old Oct 14, 2013 | 06:48 PM
vette400's Avatar
vette400
Default Hissing
While car is at idle and while hearing the hissing remove the oil filler cap and see if it goes away. If it does replace the oil filler cap with a vented one. Just went thru this with my friends car. Some of these motors will build crank case pressure especially if they have heavy modifications. Good Luck.
To Hissing sound in engine
