Launching with run flats
Jul 4, 2002 | 09:59 AM
anyone adjusting tire pressure at the track for better launching if so what pressure adjusted to :D :cheers: :seeya
Jul 4, 2002 | 10:08 AM
CI III & IV Vote Ho
CI II, III, IV & V Vet
CI IV Bracket Champ
St. Jude Donor '03-'04
Re: Launching with run flats (WHY2KRAG)
for run flats....leave at street pressure, the sidewall is so stiff, even taking out 1/2 the air will have little to no impact :eek:
I was able to pull off a 1.889 on stock runflats at stock pressure :D:D:D
Jul 4, 2002 | 11:08 AM
Re: Launching with run flats (Mean Green 2000)
I have went all the way down to 15psi - don't bother it didn't have any effect.
My best 60ft on runcraps is 2.14 but I still got a 12.78@112 ;)
:seeya
Jul 4, 2002 | 11:14 AM
CI III & IV Vote Ho
CI IV Bracket Champ
Re: Launching with run flats (Ryan2002C5)
when you get that 60' down you'll run even lower....12.564@110.21 ;) :D
Jul 4, 2002 | 11:33 AM
See sig. Got lucky and managed to time launch perfectly and get everything else right. 1.7 second 60 ft with runflats at 28 psi. :eek:
Jul 4, 2002 | 03:19 PM
Leave Em at street pressure. Lowering tire psi on these will only concave the center contact patch! Heat em up good and they'll stick.
Jul 4, 2002 | 03:29 PM
Re: Launching with run flats (Dave00C5)
Thank you :D :D will leave at street pressure :D :cheers: :seeya
