Service ABS/Traction Control
Old Oct 9, 2013 | 04:19 PM
Tim Hughes's Avatar
Tim Hughes
Cruising
Default Service ABS/Traction Control
My service ABS/Traction control lights are lit. I can't pull codes through the DIC because that isn't working. Looking for suggestions on how to fix these issues.
Old Oct 9, 2013 | 04:48 PM
RedZMonte's Avatar
RedZMonte
you need to have the codes pulled to know what the problem is or its just a shot in the dark. many shops/dealers can pull ABS codes.. you can also get a ABS code reader or repair your DIC cluster problem/get a different cluster and swap it.
S
Old Oct 10, 2013 | 09:30 AM
3boystoys's Avatar
3boystoys
Is the DIC not working at all?
Old Oct 10, 2013 | 11:35 PM
1KLRTOY's Avatar
1KLRTOY
A starting point could be the contacts in your ignition switch, a new switch cleared all the codes in my 01.
Old Nov 18, 2013 | 11:31 AM
mgmcaleer's Avatar
mgmcaleer
I started mine up the other day and received ABS and Traction Control warnings. Based on some of the other threads on the forum I was instructed to pull the codes to determine which wheels were affected and check the harness at the hub. My code showed a front left problem. I pulled the wheel and checked the connector going into the hub, no problem. I followed the wire harness from the hub to the next connector at the chassis and found my problem. One of the wires was broken. I fixed the issue and no more codes.
Old Nov 18, 2013 | 04:35 PM
guido7834's Avatar
guido7834
I was getting the same message. Cleaned all 4 connectors at the wheel hubs and it hasn't come back in several months.
Old Nov 19, 2013 | 11:27 PM
BigGun's Avatar
BigGun
This could be your no cost "shot in the dark".
Old Nov 20, 2013 | 06:17 PM
guido7834's Avatar
guido7834
Yes, I was getting the message when making the hard right out of my garage quite frequently. Hasn't happened since I cleaned the connectors. Worth a shot.
Old Nov 20, 2013 | 08:45 PM
Jeffwilson34's Avatar
Jeffwilson34
mine done that but I was able to read my code.
it is a Rf speed sensor
Mine does not come on after a restart of the engine until it starts moving.
about 20 feet and the lights pop on.
I am pretty sure its a frayed wire
I have not been able to fix iy because of health problems
To Service ABS/Traction Control
