4000 stall and drivabilty
Old Jul 4, 2002 | 11:50 AM
Slammed Vette's Avatar
Slammed Vette
Cruise-In II Veteran
Cruise-In III Veteran
Default 4000 stall and drivabilty
I was really suprised at how drivable the 4000 is!!!!Gas milage dropped some,but that could be due to the H/C too!!!All I can say is passing on the highway is awesome!!!!!!!!Took down a 911TT the other night!!!!!Stilll have some LS1 Edit trans adjustments to do to get it all dialed in!!!!!Then it's off to the dyno to test out the 3 intake manifolds(LS1,LS6,& Ported Holley)!!!!
Old Jul 4, 2002 | 01:16 PM
joe2gaan's Avatar
joe2gaan
Default Re: 4000 stall and drivabilty (Slammed Vette)
What rear end gear are you running??
Old Jul 4, 2002 | 01:53 PM
Slammed Vette
Default Re: 4000 stall and drivabilty (joe2gaan)
3.42 for now.Waiting to see how Nitrovette's car drives with the 4000 and 3.73's .Then I'll up-grade!!!!
Old Jul 4, 2002 | 03:25 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
If the 4000 feels as good as the 3500 and 3.73 it is well worth it. On the highway passing is like a rocket taking off. :smash:
Old Jul 4, 2002 | 04:28 PM
Mopar Jimmy's Avatar
Mopar Jimmy
From: Elmhurst, IL (West Suburb of Chicago) & Home of MEGA Horsepower
St. Jude Donor '06
:cool: :cheers: :smash: :jester We should know in about 2 weeks. I have high expectations!:D
Nitrovette
Old Jul 4, 2002 | 05:19 PM
2000^C5's Avatar
2000^C5
From: My barber didn't know when to quit... Do you?
Default Re: 4000 stall and drivabilty (Nitrovette)
Why are you testing the 3 intakes?
Old Jul 5, 2002 | 12:17 PM
Slammed Vette
Default Re: 4000 stall and drivabilty (2000^C5)
Because I have them and I want to show everyone on the forum that actual gains each one gets on a H/C car.
Old Jul 5, 2002 | 01:52 PM
2000^C5's Avatar
2000^C5
Cool, can't wait to hear the results. :cheers:
Old Jul 5, 2002 | 02:13 PM
gmf's Avatar
gmf
I can't wait to hear about them!! What date is this?
Also - could you or someone explain to me the meaning of stall and what the diff between a 2k,3k and 4k TQ is? Thanks!
:conehead
Old Jul 5, 2002 | 02:54 PM
gmf's Avatar
gmf
Default Re: 4000 stall and drivabilty (gmf)
:conehead
nevermind- here is a good definition i found
STALL TORQUE CONVERTERS
To understand stall torque converters, one needs to first understand the how the stall of a converter is determined. The stall of a converter can be determined by placing the transmission in forward gear, applying and holding the brakes, and depressing the throttle until the engine can no longer increase RPM or the brakes no longer hold the vehicle. The maximum RPM the engine developed is considered the stall speed of the converter. The brakes must hold the vehicle for the test to be valid.
Many factors affect the stall speed, such as the engine, cam setup, and the torque converter condition. The stall of a converter can vary significantly if placed in different vehicles. Stall converters are desirable because the can deliver the maximum torque from the engine to the transmission from a dead stop.
Old Jul 5, 2002 | 04:15 PM
Mopar Jimmy
St. Jude Donor '06
Slammed, you da man BRUDDA! Looking forward to the intake test results!
Nitro:D :cheers: :smash:
[Modified by Nitrovette, 2:16 PM 7/5/2002]
To 4000 stall and drivabilty
