Read end noise
Old Oct 11, 2013 | 01:59 AM
bikeriderga's Avatar
bikeriderga
Default Read end noise
I have a 03 Z06 with 27K miles. Lately I have noticed noise (kind of a clunk and sometimes a grinding noise at slower speeds and in turns at slower speeds coming from somewhere in the drive train (rear end or differential).
I have had all of the fluids drained and new fluid installed in the drive train (transmission, differential).
I cannot seem to isolate the noise, but it is annoying. Any ideas?
Old Oct 11, 2013 | 04:47 PM
paoutlaw's Avatar
paoutlaw
Did you change the rear end and trans fluid yourself? If so, check the old fluid to see if any metal is present. This would not be a good sign if it is. If someone else changed you fluids, I hope they looked at them for you. Its something I thought of without getting too technical. I found a lot of metal in an old Corvette's rear end oil after I had heard noise. I had to have the rear end rebuilt. I hope your problem is not this bad. Good Luck. The Outlaw
Old Oct 11, 2013 | 05:10 PM
Zorlac's Avatar
Zorlac
My wheel bearing sounded horrible when it went bad. Maybe wheel bearing?
To Read end noise
