Where do these hoses go?
Old Oct 17, 2013 | 10:25 PM
Dcollins3208's Avatar
Dcollins3208
Default Where do these hoses go?
Hey all, as I'm troubleshooting my idling problem I've found a possible vacuum problem and I was wondering if anyone could tell me where these hoses go. (Yes, I realize the engine bay is dirty, I just got the car and the previous owner did NOT keep it clean! ) . I know one hose goes to the airbox as you can see there is no hose hooked up to the airbox, it was lying underneath it (has elbow on the end that I'm assuming goes into the side of the airbox. please correct me if I'm wrong but I do not have a pic of that hose. The picture of the hose I've posted is on the driver's side, I'm taking the picture over the top of the engine facing towards the front of the vehicle. Couldn't find where this sucker goes!! It's coming out of the front of the radiator compartment it appears? Any help is much appreciated
Old Oct 17, 2013 | 10:59 PM
chris308's Avatar
chris308
a.i.r pump tied into the fittings on the exhaust manifolds i believe, its been so long since i had that crap on my car.
Old Oct 17, 2013 | 11:35 PM
Dcollins3208
Ah yes, looks like that has been removed from my car and tuned out. So this hose essentially has no function anymore correct?
Old Oct 17, 2013 | 11:47 PM
LoneStarFRC's Avatar
LoneStarFRC
If by "this", you mean the A.I.R. pump has been removed, then yes, it serves no purpose. Just be sure to close/plug the hole where it attaches to the air cleaner housing to keep dust/dirt, etc out.
Old Oct 17, 2013 | 11:50 PM
Dcollins3208
Yessir, literally just finished doing so! Thank you guys for you help. Had me baffled for a bit as I am new to the C5
Old Oct 18, 2013 | 12:16 PM
SaberD's Avatar
SaberD
looks to me like it is the vacuum line that connects to the air box. you can see in the pic the empty hole in the air box.
Old Oct 18, 2013 | 01:56 PM
Dcollins3208
Turns out the hoses went to the air pump which was removed and tuned out prior to me owning it, meaning the hoses no longer have any function. I am now looking for a plug for the air box hole, any recommendations?
Old Oct 18, 2013 | 02:26 PM
SaberD's Avatar
SaberD
clean it off and use some extreme duty duct tape on both sides of the hole. http://www.racerstape.com/rtp.html
Old Oct 18, 2013 | 02:34 PM
LoneStarFRC
Check Home Despot, Loews, Ace Hardware for hole plugs. Maybe even your local favorite AP store.
Old Oct 19, 2013 | 04:14 PM
The Void's Avatar
The Void
I used an expandable rubber stopper from lowes I believe. Has a bolt running through the center you torque down to expand it. Look in the hobby/experiment bin.
To Where do these hoses go?
