Checking oil level in D1SC Procharger
Old Oct 20, 2013 | 05:24 PM
juriah's Avatar
juriah
Default Checking oil level in D1SC Procharger
Guys,
I installed a Pro Charger tensioning bracket for my D1SC supercharer. This changed the orientation of the holes that house the oil dip stick. I installed the stainless braided tube that allows for easy oil changes. I put 6 oz of oil into the supercharger. When I read the dip stick in the lower position, it shows to much oil. If I switch the dipstick to the upper position, it shows no oil. I been on You Tube and the Forum looking at Pics of D1SCs. I see the dip stick in both locations.
Any ideas guys ? Should I just add the 6 oz of oil and don't worry about it ?
Old Oct 20, 2013 | 08:06 PM
a/c man's Avatar
a/c man
pro charger makes 2 dipsticks depends which hole you use! when u re clock the head unit it requires a longer dipstick
Old Oct 21, 2013 | 05:29 AM
juriah's Avatar
juriah
Thanks, A/C Man that's easy enough.
Old Oct 21, 2013 | 08:15 AM
Chicago1's Avatar
Chicago1
Are you talking about clocking the housing or the unit?
OP check this out maybe this will help not sure..I just clocked the housing...look for "how to clock a procharger"
http://www.aacorvette.com/supercharg...e=instructions
Old Oct 21, 2013 | 10:48 AM
a/c man's Avatar
a/c man
correct the info needed to change oil stick is where you found it on A&A good work thanks
Old Oct 26, 2013 | 10:34 AM
juriah's Avatar
juriah
I removed the gear case cover for another reason. The black end of the dipstick (7.5 inch) got caught in the end of dipstick passage at the hole for the plug. I found and removed the end of the dipstick. Looks like the oiler gear was not relocated properly when this was previously re-clocked. I can move the oiler gear. I still can't see why the dipstick is getting hung up. Its getting hung up somewhere under the input gear at the top of of the dipstick passage as it exits through the plug hole. I am not sure if this is because there is no cover on this passage. The old dipstick (7.5 inch) was previously installed into the covered passage.
[IMG][/IMG]
A&A instructions show it going into the uncovered passage. Guys with P1SCs or D1SC any thoughts. Both models have the same gear box.
Last but, not least. I am looking for a good oil seal puller to replace the gear box oil seal. Any suggestions ?
Old Oct 26, 2013 | 12:45 PM
a/c man's Avatar
a/c man
use the hole with the cover and get a longer stick from procharger $20.00
Old Oct 26, 2013 | 02:14 PM
juriah's Avatar
juriah
Based on the way the volute is clocked, the small dipstick (7.5 inch) shows too much oil. That would be true for the larger dipstick (9.5 inch). I would be pulling it through the bottom of the oil reservoir. As in the picture, the long dipstick (9.5 inch) would work from the top fill hole but, I can still feel it getting hung up. The bearings are not making noise. I really don't want to touch them. Output shaft bearings are very pricey !!
Old Oct 27, 2013 | 11:33 AM
95wht6spd's Avatar
95wht6spd
IDK, I just reclocked mine, and moved oil slinger, and drain plug. I just filled with 1 bottle and seems fine, but didn't check level since that is recommended amount. I added one of the drain tubes as well. I figured with the tube, it has a little less than in unit without tube. I purchased the longer dipstick to.
To Checking oil level in D1SC Procharger
