brake lights
Old Oct 21, 2013 | 07:19 AM
c5vette211's Avatar
c5vette211
St. Jude Donor '14
Default brake lights
Had something strange happen yesterday. Someone informed me my brake lights were out so i checked the fuse and sure enough it was blown. So i swapped the fuse but only passenger side was operational. A few min later the fuse blew again. The odd thing was when I pressed on the petal the interior lighting went off. the gauge lighting only. the gauges were still operational. Has any one seen this before or able to shed some light on this?
Old Oct 21, 2013 | 11:51 AM
dadaroo's Avatar
dadaroo
Does the 3rd center brake light work? That will tell something about what is going on. Sure sounds like a short somewhere. The 3rd brake light power is routed around the Hazard and Multifunction switches.
Old Oct 21, 2013 | 12:40 PM
c5vette211's Avatar
c5vette211
St. Jude Donor '14
I didnt check that but i do know when the fuse blew the hazards where not working. then i replaced the fuse and only one side was blinking with the hazards on.
Old Oct 21, 2013 | 12:41 PM
c5vette211's Avatar
c5vette211
St. Jude Donor '14
I am going to take the lights out/bumper off tonight to see if there is any wires touching. Im hoping that the all it is...
Old Oct 21, 2013 | 06:38 PM
c5vette211's Avatar
c5vette211
St. Jude Donor '14
took the lights out and found the wires melted together..... I like easy fixes.
Old Oct 22, 2013 | 08:11 AM
dadaroo's Avatar
dadaroo
Glad you found it without too much trouble.
Old Oct 22, 2013 | 11:15 PM
c5vette211's Avatar
c5vette211
St. Jude Donor '14
ok back on it.... the lights started working when i press the brake. the instrument lights came back. But now when the headlights are switched on the tail lights are not coming on. Could the wires that were touching have caused some other issues? I have been reading up on the multifunction switch but I am not showing any other symptoms and all of these issues started with the melting of the wires.
Old Oct 23, 2013 | 05:52 AM
65GGvert's Avatar
65GGvert
I assume you checked fuse #6 in the passenger foot well after your repair?
Old Oct 23, 2013 | 07:15 AM
c5vette211's Avatar
c5vette211
St. Jude Donor '14
Yea I did check that fuse. That was the fist thing I did that and 8. However all is well.... I woke up this morning and everything was working fine.... i guess she just needed some time to think about what she did....
To brake lights
