Clutch adjustment?
Old Oct 21, 2013 | 10:51 PM
anothertoy's Avatar
anothertoy
Default Clutch adjustment?
I have a 500hp/500tq engine with a LS7 clutch. It has always engaged low and was wondering if there is any way to adjust it?
Old Oct 21, 2013 | 11:24 PM
racebum's Avatar
racebum
yes actually. ram makes an adjustable master cylinder that will allow you to change the engagement point. it's a GM oem master with a threaded rod
tick also makes one as well as mcloud but they will increase pedal pressure due to the larger pistons in them
Old Oct 22, 2013 | 10:20 AM
SaberD's Avatar
SaberD
it is also possible that you may have needed to add a shim to the slave cylinder. Did you take the measurements between the pressure plate fingers and the back of the bell housing and the thickness of the slave?
Old Oct 22, 2013 | 03:18 PM
BOUT X's Avatar
BOUT X
Corvette Cowboy
I have the Tick adjuster on my car works great, But I dont think it is the correct way to fix the problem BUT it works great.
Here is the correct way to fix the issue But you need to be right on with the shim or you can damage the clutch. Get a hold of Richie @ Abel he is the one that shared this info with me a couple yrs. ago when I used the LS7 Clutch I now have a clutch custom made by TPS and it works great with the Tick adjuster.
Old Oct 22, 2013 | 03:32 PM
racebum's Avatar
racebum
that's just an insane amount of work to do if a master cylinder could change the pedal to his liking? as long as he's not past the range of useable adjustment it would sure be much more simple than tearing the drive line out to make a measurement
Old Oct 22, 2013 | 07:04 PM
anothertoy's Avatar
anothertoy
The clutch only has about 5K on it but always engaged low to the floor. Now I'm getting resistence going into gears when the car is warmed up. It's kinda variable. The tranny has 75K on it but it seems weird that multiple gears would be messed all at once. Just looking for ideas. Thanks for the replies.
Old Oct 22, 2013 | 07:30 PM
racebum's Avatar
racebum
well, if you didn't have enough travel and the slave did need a shim it would make sense. you're simply not able to push the clutch in far enough
the ram master is like $200 and may fix your problem, if it doesn't you'll have to tear the car apart
personally i would try the ram just because it's simple and really could fix the issue by dialing in more travel
Old Oct 22, 2013 | 07:35 PM
bcperry's Avatar
bcperry
I had the same issue (on a stock ls1 clutch though) and installed a tick master. I haven't had any problems since. My issues with engagement started out intermittent, but became so bad that I had to clutch less shift any time I drove it. Try changing the brake fluid in the master cylinder out( use the ranger method) if it had dirty fluid, and if that doesn't work just drop in an adjustable master.
Old Oct 22, 2013 | 08:19 PM
sami85L98's Avatar
sami85L98
Before you spend any money, take the car to track or nobody is on the road, drive like you racing 1/4 mile, do it couple times......thats it.
I am opposite, i install new clutch do some breakin period few hundred miles and than rip it let it eat, release bearing pp....everything will settle where they supposed to be.
I assume you have no air trapped in the system and bleed it right....if its still not right and engaging at the floor than you have 2 options, 1> Tick adjustable master or do on your own stock modified (you may possibly send yours to rpm motors charlie or A&A to make it adjustable and send you back.....ask them first if they can do...or 2> uninstall diff/tranny TT and install Shim (get it from Tick shift).
Edit: I brutally hate Tick shift adjustable master......make your pedal rock solid, i had it for few months and i sold for cheap.....only advantage i was able to raise pedal higher and shift 3-4 at the track...but on street.....son of ........ damage my knee i still had pain even after one year.
GL.
Old Oct 22, 2013 | 10:35 PM
anothertoy's Avatar
anothertoy
I have a remote bleeder and did that this weekend. It helped but didn't solve the problem. I may just bleed it again, buy something more is going on.
Old Oct 24, 2013 | 03:54 PM
sami85L98's Avatar
sami85L98
Read my post previous again.....i said take it remote place and drive like you doin 1/4 mile racing....take it 5k rpm, just couple runs and thats it.....your pedal engage height will be higher.
Old Oct 24, 2013 | 08:17 PM
JT97C5's Avatar
JT97C5
I have the exact same problem. And my driveline is on the floor as we speak I'm replacing the slave due to way to much clutch dust. Since it's apart can someone point me in the right direction on shiming the slave. I have a Ton of shims from jet ski parts. Any where from .5mm -4mm
Old Oct 26, 2013 | 10:13 AM
JT97C5's Avatar
JT97C5
So put the new slave in and didn't shim because I was unaware on how to shim it and the new slave seems to help but the clutch is still not releasing all the way. I went out and picked up a tick MC putting it in now and I will post if it fixes these problem.
Old Nov 11, 2013 | 11:57 PM
anothertoy's Avatar
anothertoy
Did the tick help???
Old Nov 12, 2013 | 01:50 AM
Mickeyrx70's Avatar
Mickeyrx70
To Clutch adjustment?
