missfire
Old Oct 22, 2013 | 10:40 PM
jetmech09's Avatar
jetmech09
Default missfire
car started to misfire under load. I pulled plugs to check if bad . found all plugs looking like new to clean if you ask me ,looks they came strait out the box. I am thinking way to lean. I have a A&A supercharger at 10 psi on a mild cam stock engine . any thoughts?????
Old Oct 23, 2013 | 08:33 AM
JetMechZ16's Avatar
JetMechZ16
Ohm plug wires, check for vacuum leaks, check coils, injectors, wiring harness that wraps around bracket near fire wall on drivers side, sometimes it chafes the bracket and shorts.
