What do these sounds mean?
Old Oct 23, 2013 | 12:25 AM
rklimt's Avatar
rklimt
Default What do these sounds mean?
I have a small video clip for review. The sounds only occur when I first start the car in the morning, after driving for about 5 minutes they disappear. There is a squeak and then a very noticeable knocking sound. This is a 2000 LS1 with 51,570 miles. If anyone can identify the sounds and/or has any suggestions on how to correct, I would appreciate the advice. Thanks Here is a link to YT where I posted it.
Old Oct 23, 2013 | 12:30 AM
CactusCat's Avatar
CactusCat
Take the belt off and start the car. See if the noise goes away. My guess is one of the idler pulleys is worn out. Very common on our cars. While the belt is off, spin the pulleys by hand. If they're free wheeling, they're worn out. They should have a small amount of tension on them. They'll turn slowly if they're in good shape. This check will take you less than 5 minutes total. All you need is a rachet and 15mm socket.
Old Oct 23, 2013 | 08:01 PM
ace147's Avatar
ace147
http://youtu.be/QlCv04OtDjo
Sounds like an acdelco belt at 50k
Try a goodyear gatorback belt first.
Old Oct 23, 2013 | 09:20 PM
rklimt's Avatar
rklimt
Thanks very much, appreciate your taking the time to reply and for the advise.
rklimt's Avatar
rklimt
To What do these sounds mean?
