Replacing the Slave help? 97 c5
Old Oct 24, 2013 | 08:45 AM
JT97C5's Avatar
JT97C5
Default Replacing the Slave help? 97 c5
Hey guys im replacing my slave cylinder. heres the story i had Vette doctors replace my clutch with a CF clutch about 10k ago the clutch still has a lot of meat so i think its safe to rule that out. The car will not shift past 5k rpm i have to wait til it drops below that in order to shift 2nd which i believe is because the master hydraulics. and one day i found that pushing the clutch in does absolutely nothing it only pulls the clutch off the flywheel about 1mm. Im assuming this happened because i never cleaned my fluid and i drive the car real hard. i heard that once he slave gets dirty there is no cleaning it. anyways what im asking is will replacing the Slave going to fix this problem. Right now i have the whole assembly on a jack waiting to be pulled back. and any tips on how to remove the ABS module in the back. Just for clarity i have tried the search many times
Thank you for any help
Old Oct 24, 2013 | 01:18 PM
zeevette's Avatar
zeevette
Worth it to replace the MC first, in case that's the source of your problem. It's far easier than the slave, which requires torque tube removal. Try a Tick MC; much stouter than stock, and I recommend using a 3/4" bore, rather than the normal 7/8". Either way, a Tick will flow more fluid than a stock replacement. Assuming you have a new slave when you had your clutch installed, then it shouldn't be the problem.
Old Oct 24, 2013 | 02:08 PM
JT97C5's Avatar
JT97C5
I replaced the MC when it first happened then after about 3 weeks it did it again.
Old Oct 24, 2013 | 02:32 PM
zeevette's Avatar
zeevette
So... putting a new MC worked fine for 3 weeks?
Old Oct 24, 2013 | 02:46 PM
JT97C5's Avatar
JT97C5
I wouldn't say fine, it did fix the pedal doing nothing but I was still unable to shift past 5k. If it matters when I had the pedal to the floor and shifter was in 1st if I revved it up to 4500-5000 it would start to roll
Old Oct 24, 2013 | 04:56 PM
zeevette's Avatar
zeevette
Read the other thread; same situation, maybe same solutions.
http://forums.corvetteforum.com/c5-t...djustment.html
To Replacing the Slave help? 97 c5
