Dyno Numbers
Old Jul 5, 2002 | 10:42 PM
pjazz's Avatar
pjazz
C6 of Year Winner (performance mods) 2019
Default Dyno Numbers
I finally had our car dyno'd for the first time. Pretty much all of the mods were on the car when we purchased it. RWHP 348.9 RWTQ 348 This was on a Dyno Jet on a pretty hot 90 degree day. I was hoping to see a little higher numbers for a heads and cam car, but I figure adding more mods my self will be part of the fun. :chevy Dyno Graph: http://temp.corvetteforum.net/c5/pjazz//dyno.jpg
Old Jul 5, 2002 | 11:24 PM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI II, III, IV & V Vet
CI IV Bracket Champ
St. Jude Donor '03-'04
Default Re: Dyno Numbers (pjazz)
that does seem kinda low for a h/c car.....hmmmmmm :confused:
Old Jul 5, 2002 | 11:28 PM
MDL-01C5's Avatar
MDL-01C5
Default Re: Dyno Numbers (Mean Green 2000)
are you sure you have an aftermarket cam, and heads, for that matter :confused:
Something is WAY not right if you do..... :confused:
Old Jul 5, 2002 | 11:29 PM
wave_3's Avatar
wave_3
Active Streak: 90 Days
Cruise-In III Veteran
Default Re: Dyno Numbers (MDL-01C5)
I agree, you should be way closer to 400RWHP.
Old Jul 5, 2002 | 11:55 PM
pjazz's Avatar
pjazz
Default Re: Dyno Numbers (wave_3)
I've got most of the reciepts. The heads have CNC stamped right on them. I also have card from comp cams with it's specs. Unfortunately I'm not sure how to read the numbers. I planned on calling them to see if it was just a very mild cam.
Old Jul 6, 2002 | 12:30 AM
MDL-01C5's Avatar
MDL-01C5
The cam specs will look like this:
(for example) 226/226 .591/.591 112
the first two numbers are the exhaust valve/intake valve duration (the amount, in degrees of rotation, that the valves are open out of 360)
the second two numbers are the lift, in inches, that the I & E valves are open, and the last number, 112, is the lobe separation angle, in degrees as well...
Old Jul 6, 2002 | 12:40 AM
pjazz's Avatar
pjazz
There's alot of numbers on this card . Says gross valve lift .525/.532
Duration at .006 tappet lift 269/273 . Are these the numbers I'm looking for and do they sound in line with the HP?
To Dyno Numbers
