Adjusting/Replacing Belt on Procharger Bracket System
Old Oct 27, 2013 | 11:42 PM
juriah's Avatar
juriah
Default Adjusting/Replacing Belt on Procharger Bracket System
Guys,
I had this set up since 2008. I really have not had to touch it to many times. I am forgetting something basic. I am having trouble getting the tension pulley to engage when I use the brass drive bolt in the back of the bracket. It does not seem like the bolt travels far enough around that radius slot located in the rear of the bracket. Does anyone have instructions for this Pro-charger Bracket ? Set up would probably be the best. Something is off.
Alignment Mark photo - Mark on upper left; Left of seam. Should be located between two marks on right
Adjustment nut in rear
Properly aligned
Old Oct 28, 2013 | 07:57 AM
c5austin's Avatar
c5austin
I am not familiar with that bracket and tensioner, you may take these pics to the forced induction section as I am sure a couple of those guys can help you out
