I have posted a couple of times about this without resolution. I installed a new battery ( it is a good one). Ran the codes with the ignition off, cleared the codes and ran them again with the engine running. Did this 6 times.
TC icon comes on then the dreaded AH needs service/ vehicle needs service soon.
The codes are: TCS C1288 C H and RFA U1064 C H. These codes repeat themselves each ignition cycle. The car has recently had an alignment, steers straight on the highway. I cleaned the grounds.
My research shows it needs the SWPS changed out. Maybe the EBCM also?
Any advice will be greatly appreciated.
Phil G
Phil G
Yep, that's the swps. Tons of fun to replace. Couple hours. Follow the instructions precisely.
