Tire and wheel question
Old Nov 4, 2013 | 12:31 PM
guido7834's Avatar
guido7834
Default Tire and wheel question
I have a chance to buy a set of c6 wheels and tires.
Sizes are: 255-40-18 fronts and 285-35-19 rears.
Will these fit my stock c5 without any issues?
Old Nov 4, 2013 | 12:42 PM
Zorlac's Avatar
Zorlac
Because of difference in rear offsets you may decide to add a spacer to get a more flush look. But they'll work. I'm assuming with a 285 they're not 12" wheels.
Old Nov 4, 2013 | 01:19 PM
guido7834's Avatar
guido7834
What do you mean 12" wheels?
Old Nov 4, 2013 | 01:30 PM
guido7834's Avatar
guido7834
Forgot to mention, they're toyo t.1r tires
Old Nov 4, 2013 | 01:31 PM
Kreeess's Avatar
Kreeess
heard your gonna need to run spacers for the rear if these are stock c6 sets due to different offsets
Old Nov 4, 2013 | 01:39 PM
Zorlac's Avatar
Zorlac
Wide body C6's have a 12" wide rear wheel I believe. I'm pretty sure they won't fit under a C5. I may be wrong. Standard C6 wheels will fit.
Old Nov 4, 2013 | 03:23 PM
guido7834's Avatar
guido7834
He had them on his c5.
Old Nov 4, 2013 | 03:33 PM
brent_torque_travis's Avatar
brent_torque_travis
4th Gear
They will work with a spacer
Old Nov 4, 2013 | 03:40 PM
guido7834's Avatar
guido7834
Is there a certain size spacer needed?
Old Nov 4, 2013 | 03:51 PM
racebum's Avatar
racebum
you can only use a 5mm spacer with stock lugs, any longer requires arp extended lugs
Old Nov 4, 2013 | 04:51 PM
guido7834's Avatar
guido7834
Old Nov 5, 2013 | 08:59 AM
guido7834's Avatar
guido7834
Originally Posted by 8VETTE7
Another alternative is wheel adapters. To bring the C6 wheels and tires out flush to the fenders you need about a 1" wheel adapter, the minimum thickness they are made in. Most are looking for the flush appearance but your tastes may accept the "sunk in" appearance that the C6 wheels will have when mounted on a C5. There are also reproduction C6 wheels made in offsets that work better on the C5 than do the C6 factory offsets.
And where could I get them from?
To Tire and wheel question
