Stupid me turned my temperature **** too hard and it clicked past the stop, so I can spin it all the way past the last red heat mark.
The temperature still works fine, but it's bothering me that I broke something. Does anyone know what stops the **** from going past the last mark and is it fixable?
Are you talking about the passenger side temp control? I don't think the driver side temp control has a stop. It will continue past the temp range, but the temp. just will not go any higher or lower.
Based on how the switches are mounted, most likely the stop is built into the switch, so switch would have to be replaced.
You might try contacting Tim in Dubois, PA (tstar) who repairs these control heads and see if he can either fix it, get you a switch, or get a rebuilt control head.
