Help --Code 2723-Pass KEY
Old Nov 10, 2013 | 02:42 PM
David Shiel's Avatar
David Shiel
Default Help --Code 2723-Pass KEY
Detection circuit.
When I pulled the middle plug and the other two to remove the BCM to check pins on the BCM, a wire was loose and came out. It is black and white. Just need to get it on the right place on the plug.
Don't know where to reinstall it on the plug. CAR WILL NOT START. It is the original BCM and was starting fine before I removed the BCM from the car.
Anybody got a diagram. And, shouldn't the car start with original BCM back in.
Tried Sam, but he is likely out somewhere.
