FAST Injectors
Old Nov 10, 2013 | 07:59 PM
m6 c5's Avatar
m6 c5
Default FAST Injectors
Has anyone used the fast 36 injectors? I need to get some larger injectors and was wondering how well they fit.
Old Nov 11, 2013 | 08:38 PM
m6 c5's Avatar
m6 c5
Anyone?
Old Nov 12, 2013 | 02:22 AM
NukeC5's Avatar
NukeC5
Yup, I have them on my build. I am using the stock fuel rail with them on the fast 92mm intake. They should fit an LS1/6 intake too. Stock wire connectors work too.
Old Nov 12, 2013 | 05:27 AM
m6 c5's Avatar
m6 c5
So no problems with height using the stock fuel rail
Old Nov 12, 2013 | 10:22 AM
NukeC5's Avatar
NukeC5
The fast 92 was designed to accept the stock rail and injectors. I used the fast injectors with the stock rail on it on you can see that the rail sits perfectly into its designated crevice (which is where it was meant to sit with the stock setup). So I assume they are exactly the same fitment. No height issues.
To FAST Injectors
