98 air bridge question
Old Nov 12, 2013 | 03:11 PM
Kreeess's Avatar
Kreeess
Default 98 air bridge question
ok so here is my dilema... i currently have an aftermarket intake/ air bridge on my 98 coupe, since its a 98 i needed to drill the airbridge for the IAT to be fitted, by end of the month im doing an Ls2 MAF swap. so that will be the 3pin to 5 pin conversion eliminating the IAT sensors... my question is what do i do with the previous hole with the sensor, can i block it off and if i can how do i go about doing so? anyone else with an earlier model go through this? dont really want to spend on a newer model air bridge when mine is still good... thanks in advance !
Old Nov 12, 2013 | 04:52 PM
MG RED 99's Avatar
MG RED 99
No need to replace it, Just go down to the autoparts or hardware store and pick up a rubber plug/grommet for the size hole you have. you should be able to just birng the grommet you have now where the iat fits into and just tell them you need a plug in the similiar size. For added protection you can also silicone the plug in place as well. This will insure it doesn't fall out, but if you get a plug that fits tight it shouldn't be a problem.
Old Nov 12, 2013 | 04:57 PM
Kreeess's Avatar
Kreeess
thank you! this was the answer i was looking for!
Old Nov 12, 2013 | 07:08 PM
NukeC5's Avatar
NukeC5
Yep, I played that game before. Not hard to plug a hole. As mentioned, buy a rubber plug. Likely you will have to get a kit full of various sizes.
Old Nov 12, 2013 | 08:58 PM
Kreeess's Avatar
Kreeess
Did u upgrade to a 5pin MAF if so how did u like it? My car has ls6 intake /heads and can do u think ill notice a difference
Old Nov 13, 2013 | 02:31 AM
NukeC5's Avatar
NukeC5
Yes I went to the 85mm maf. honestly its more trouble than its worth. You wont notice a difference by swapping it out and it takes some serious tuning to get it set up. Its nice, I guess, to know that theres more potential for air flow, but even on my heads, cam, intake, etc. car it really makes little to no difference. I think Ive read that the stock maf is good for 600ish hp. Im making 400 whp, so its not really necessary.
Old Nov 13, 2013 | 02:46 AM
Kreeess's Avatar
Kreeess
Thanks for the input, luckily I'm already scheduled for a dyno n tune and my tuner is pretty knowledgable so I figured might as we'll add it with the tune since everything cost me less than $150 for ls2 maf/ harness otherwise I would have held off till it was really necessary
To 98 air bridge question
