TB issues
Old Nov 12, 2013 | 07:18 PM
NukeC5's Avatar
NukeC5
Default TB issues
I keep having the car go into reduced power mode with a TPS code coming up. This is maybe one out of 5 startups. And typically will happen more on an initial startup in the cold mornings.
Ive removed it, cleaned it, inspected all the wires etc.
I'm not sure yet that this has to do with only when its cold out, but that seems to be the most likely time for it to happen. I have a little scan tool that allows me to clear the code and then the car is normal and drives fine. But a few days later, it throws the code again and I have to reset it again.
Its an LS2 TB that has never given me problems before.
Like I said. Car is totally fine after resetting it and there are no codes or anything for a few days. Then on a random startup it goes into reduced power mode with the TB as the problem.
