Question on Eibach Lowering Springs
I plan to do the Pfadt Johnny O'Connell Stage 1 kit but this doesnt affect ride height. I just hate the stock gap with the HREs on the car. I have a question about their advertising...
"This kit for the C5 Corvette will lower you Corvette's stance from 0 - 2.0 inches in the front & rear. This kit can give your car a more muscular stance, and improve handling, without compromising clearance! Fits 1997 - 2004 Corvette!"
Stance -sure
improved handling - iffy but don't care. Stage 1 will take care of that
no compromise on clearance - ?!?!?!?!?!?
That is my question. How can you possibly lower the car and not compromise clearance?
Is it just the body this brings down? I just don't get it. Thanks for chiming in. Oh and experienced opinions on the Stage 1 package would also be appreciated
it allows you to lower it more then stock bolts.. THATS it.. So try lowering it with stock bolts 1st and see how you like it. Lowering the vehicle an inch or so wont be the end of the workd for suspension ride. make sure you get a GOOD alignment after all the work is done and it will handle fine. you adjust the bolt to where you are happy with Height vs Clearance. there is a HOW TO LOWER YOUR VETTE post on here if you search.
I have heard nothing but good things about JOC Stg1 setup and its a good price.. you can also do C6Z06 shocks with C6Z51 sway bars/Metal sway end links if you want to save a couple bucks, not quite as good as the JOC setup but definatly better then stock C5 (non Z06) setup... especially if its getting old or high mile.
Lower the stock bolts 1st then if it doesnt sit low enough then spring for longer bolts...
Eibach Lowering kit (NOT SPRINGS):
S
