Oxygen sensor pigtail replacement
Old Nov 18, 2013 | 07:53 PM
Kreeess's Avatar
Kreeess
Default Oxygen sensor pigtail replacement
After having my LT headers installed I've been living with the 153 & 133 codes so finally I change the o2 sensors recently to try and get rid of the codes... Unfortunately I'm left with the p0133 code so I check everything and I realized that the wiring harness coming from te engine is burnt off... Is there a sticky on how to get to the harness or how to solder a new pigtail?
Old Nov 19, 2013 | 10:22 AM
Kreeess's Avatar
Kreeess
anybody ?
Old Nov 19, 2013 | 11:27 AM
JetMechZ16's Avatar
JetMechZ16
Bosch makes an o2 sensor that comes with wire connectors so you can tap into the wiring harness without having the factory pigtail. I had to use this due to my connector being completely melted. It comes with instructions that list different wiring colors on your vehicle and how to connect it your harness.
Old Nov 19, 2013 | 11:31 AM
Kreeess's Avatar
Kreeess
my o2s were recently changed... waitin for my mechanics response if he noticed anything melted at the time he swapped the o2 for me.. im not quite sure if i looked at the right connector...
To Oxygen sensor pigtail replacement
