If you go to a GM dealer and ask if there are any recalls on your car ,they will tell you which ones were done and if there are any that were not done yet.
Is there a list of recalls somewhere? I have owned my 2001 since new and have never received a recall notice. Would be interesting to see if GM failed to send it or not.
If you get a copy of the GMVIS for your VIN that document would list any recalls that were still open (ie not performed to the car). It would also indicate recalls that are closed (performed) along with the date and a cryptic description.
Keep in mind that any recall of the car could have been performed by the dealer if you ever had the car back to the dealer for anything including a simple thing like an oil change. While most dealers will tell you that they performed a recall, they don't have to tell you anything.
You can get a copy of the GMVIS for the car by sending an email, with your VIN and asking them to email it back, to either of the following two Forum Supporting vendors:
OK, did the VIN number check and it says there are no active recalls for my vehicle. It is a 2001 manual. I have never been advised on any work on the column lock, Nor is it listed on any of the paperwork I have from the dealer since new, so I guess I'll try to get a copy of the GMVIS.
Maybe this would be a good time to do the CLB column lock bypass
that disables the column lock and keeps the BCM from throwing a code.
It's only 40-50.00.
You don't want to get stranded and have to have the car towed to a dealer
as this seems to be a common problem that happens eventually.
It's pretty easy to do.
It's not something the dealer does.
